Emergency! Help
Old Nov 16, 2007 | 07:52 AM
tndiesel's Avatar
tndiesel
Emergency! Help
I went out and started my truck this morning. The key is in it and it's running and my clicker will not open the lock on the doors!!! I don't even remember locking it, how in the heck am I going to get it open? I need to be at work and my truck is running with a 1/2 tank of fuel!! It will run forever! Seriously, this is not a good situation!! Help please!!
Old Nov 16, 2007 | 07:57 AM
tjbeggs's Avatar
tjbeggs
gonna have to break in. Do you have a sliding rear window? those are easy to get open with a small screw diver or butter knife. Or if not you need a coat hanger and some paint sticks. Get the paint sticks in the top or front slant of of the door to open it up a crack then slide you straightened out hanger to hit the lock button.
Then after work get three spare keys made up. One in your wallet, one in your house, one to your wife, maybe even one more tapes/strapped to the underside of your truck.
Old Nov 16, 2007 | 08:01 AM
tndiesel's Avatar
tndiesel
No sliding rear window, I wish! Just a straight coat hanger and pull up? Is the lock bottom directly below the door handle or where?
Old Nov 16, 2007 | 08:09 AM
powrstrkr's Avatar
powrstrkr
Get a thin piece of metal and bend it 90deg. Slide it under the rear of the vent window just above the weatherstrip and pull the button on the vent window lock towards you. Then slide another straight piece of metal under there and push the lock rearward. Then open the window and stick your arm in. Easy to do if you know how.
Old Nov 16, 2007 | 08:22 AM
1997F-350's Avatar
1997F-350
well since you have an XLT go in through the wing and hit the unlock button with a coat hanger. dont ask how i know this. hope you have it unlocked by now though.
Old Nov 16, 2007 | 08:45 AM
tjbeggs's Avatar
tjbeggs
By lock button I mean the power lock/unlock button
Old Nov 16, 2007 | 08:57 AM
Neal 97 250's Avatar
Neal 97 250
That is the best way. You canslide a coat hanger thru the vent window and have the hanger bent at 90 degrees that way you can tap on the unlock button till it unlocks.
Old Nov 16, 2007 | 09:04 AM
rockyrider's Avatar
rockyrider
Locksmith???
Old Nov 16, 2007 | 09:31 AM
61 uni's Avatar
61 uni
Did you get it unlocked?
Old Nov 16, 2007 | 09:33 AM
cchildress's Avatar
cchildress
I have sratchs on the plastic from doing this with a coat hanger. Remote start can get you in trouble. Hope you made it to work!!
Old Nov 16, 2007 | 09:45 AM
Talyn's Avatar
Talyn
These are all great suggestions.
Old Nov 16, 2007 | 10:09 AM
MADVAN's Avatar
MADVAN
Hacksaw blade.
Have even used them as a slimjim.
Bill
Old Nov 16, 2007 | 10:19 AM
tjbeggs's Avatar
tjbeggs
Originally Posted by MADVAN
Hacksaw blade.
Bill
Sounds painful and a bit rough on door seals!!
Old Nov 16, 2007 | 10:20 AM
wycowboy's Avatar
wycowboy
you can go in, on between the window seal you use a "u"shaped bit of 1/4" round rod.
you put i in the door move the end of the "u" under the veritical lock button annd lift. works well very easy.
but i'll bet you are already in,, best thing to do is to tape a spare key to the brake line so you always have one.. best of luck.. J
Old Nov 16, 2007 | 10:31 AM
powerstroke 96`'s Avatar
powerstroke 96`
Brick=window works every time but expensive
