white smoke?
Old Nov 16, 2007 | 07:24 AM
robs01f250's Avatar
robs01f250
white smoke?
I started my 01 f250 7.3 this morning and there was white smoke pouring out the exhaust it was about 32 degrees outside and I forgot to plug I'd up last night. Is there something wrong with my truck
Old Nov 16, 2007 | 07:57 AM
Pocket's Avatar
Pocket
Excessive white smoke is usually a sign of a bad glow plug or two. Ohm them out at the valve cover harnesses and you can see how many are bad.
Old Nov 16, 2007 | 08:06 AM
robs01f250's Avatar
robs01f250
where are they and how many do I have
Old Nov 16, 2007 | 08:26 AM
Pocket's Avatar
Pocket
Look on the valley side of each valve cover, and you'll see the valve cover harnesses that run underneath each cover. When you remove the plug, you'll see that each connector has 8 pins. The outer two pins on each side of the connector is for the glow plugs, the 4 middle are for the injectors:
UVC Harness connector
G - glow plug
I - Injector
|G|G|I|I|I|I|G|G|
Take a multimeter and OHM out each pin for the glow plugs. The black lead of your multimeter should be connected to a good ground, and probe the red lead into each of the glow plug pins. Good glow plugs read between .8 to 1.5 OHM's. Marginal glow plugs will be slightly higher than 1.5, but it you're reading much higher than that or to infinity then they need to be replaced.
Old Nov 16, 2007 | 09:37 AM
nhill2090's Avatar
nhill2090
you should also check your glow plug relay
the GPR109 from NAPA and Oreilly's is only $20 and as cheap as it is, i went ahead and replaced it when i did my glow plugs
Old Nov 16, 2007 | 10:11 AM
pullinair's Avatar
pullinair
Remember one thing, these trucks do not HAVE to be plugged in to start when cold! Fresh batts, good synthetic oil and a working glow plug system will be enough to start your truck in even below 0 deg, without being plugged in. Oh yeah, good compression too!
It sounds like your truck has a failing Glow Plug Relay though. Do a search on here for hard starting or cold weather tips. This subject has been covered a million times. I've been doing cold start-ups without plugging in admist having my oil monitered, and all UOA have checked out great. Energy costs too high right now!
Old Nov 16, 2007 | 10:15 AM
WonderDonkey's Avatar
WonderDonkey
G - glow plug
I - Injector
|G|G|I|I|I|I|G|G|
Just forgot the ground, there is actully 9 pins
(G) (G) (I) (I) (C) (I) (I) (G) (G)
G=Glow plugs
I=Injector
C=Common Ground
Old Nov 16, 2007 | 10:21 AM
BADBLUEOVAL351's Avatar
BADBLUEOVAL351
I definitely agree with what everyone's saying i had a 95 7.3 went to start it one day and just crank and dumped white smoke (unburnt diesel) Scratched my head jumped the glow plug soleniod by fuel filter and she fired right up. easy repair and cause of problem. The next week i threw glow plugs in her too just so i wasn't stranded cause who knew how old they were and when they were ready to quit just like my solenoid. ohm your glow plugs or just say screw it and buy a rack they're not to to bad at least you know they're all new. good luck
Old Nov 16, 2007 | 12:48 PM
Pocket's Avatar
Pocket
G=Glow plugs
I=Injector
C=Common Ground
Yep, I forgot the ground. Doh! Thanks for the correction.
Old Nov 16, 2007 | 05:04 PM
SUCKMEUP's Avatar
SUCKMEUP
that happen to me this morning also, truck has been parked for about 3 weeks havnt moved it till today decided to go fuel her up and after i fueld her up white smoke was comming out and then she lost power till she just shut down on me, come to be the damn filter was really REALLY dirty new filter and bam she fired right up and purred donw the street like a lion
