Offroad & 4x4
Growl when in 4x4!
Old Nov 14, 2007 | 10:57 PM
beerdude41867's Avatar
beerdude41867
Growl when in 4x4!
I very, very rarely put my 2001 F-350 PSD in 4x4. But I had to last week pulling my 9000lb trailer slowly, about 2 miles through the desert sand. When I would accelerate up a hill or slope my transfer case had a mild grone. Is this normal. Should you be able to hear and feel when you're in 4x4?
Old Nov 15, 2007 | 12:38 AM
75F350's Avatar
75F350
Could be a bearing that was, or is dry from not being used. Were you in low range, or in high range? Low range will make some gear noise, and I can always tell when my truck is in 4wd. Heak I can even tell when the hubs are locked and the t-case is still in 2wd.
Once you determine the problem, you should probably consider engaging 4wd a bit more often, or at least drive it some with the hubs locked.
Old Nov 15, 2007 | 05:45 AM
fishmanndotcom's Avatar
fishmanndotcom
i can hear my t-case growl when i am in 4-low but in 4-hi you should not notice a difference unless you are at a high speed. but then you would notice more vibration and more noise from the front end.
you NEED to run 4-wheel about once a month. even if its just for a mile or so, lock the hubs and and go to town. its the age old saying... you dont use it, you will lose it! very true in this case. the bearings will get dry and metal to metal will touch, the seals will dry out and start to dry rot and then leak, the shifting mechanism can get stuck in one position from no movement after so long, etc, etc.
-cutts-
Old Nov 15, 2007 | 06:50 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
auto or manual?
Sounds normal for a manual truck
xxcoldbeerxx
Feb 1, 2009 05:20 PM
emt676
Feb 6, 2008 10:49 AM
Jimmy124
2004 - 2008 F150
Nov 16, 2007 06:58 PM
masseysbronco
1978 - 1996 Big Bronco
Apr 29, 2005 09:24 AM
67f250
1997 - 2003 F150
Feb 5, 2001 05:38 PM
