Sponsored by: Real Truck
2003 F-250 - spring code XA
Old Nov 14, 2007 | 09:31 PM
WickedSharp's Avatar
WickedSharp
Hello,
I have a new to me 2003 F250 SD with spring code XA, which I understand is the snow plow package. The rear of the truck sits lower than the front. What options do I have to level it out. I know, it sounds wierd that I need to level the truck because the rear is too low. Most have the opposite problem.
Is ordering a set of Code B rear springs my best bet?
Old Nov 14, 2007 | 09:50 PM
aldridgec's Avatar
aldridgec
I think the only difference is that the B code springs don't have the auxiliary springs. How many leaves do you have on the front axle? If you bought it used, it is common for previous owners to have them upgraded if there was a plow. I've had two trucks like this. Not sure why the rear would be lower unless something sagged, or broke. Without new springs, you could get the 4 inch blocks if you already have the 2 inch blocks.
Old Nov 15, 2007 | 10:31 AM
wlihntr's Avatar
wlihntr
as stated above, the easiest thing to do would be to replace your factory 2" rear blocks with a set of 4" ones from an F350
Old Nov 15, 2007 | 10:39 AM
WickedSharp
I just read through the threads that detail swapping out the 250 block for a 350 block. I will give this a try.
Thanks
Old Nov 15, 2007 | 11:18 AM
L-N-OR's Avatar
L-N-OR
It doesn't sound strange to me...I have same X code on my 2001. I used a 2.5" add a leaf all the way around...and the truck sits pretty level now, may still be a tad high in the front, but not as much as before.
They say the add a leaf adds 1.5 to 2.5...so maybe it was on the high side for the rear and low side on the front??
mikeycars
May 21, 2016 02:43 PM
mainefordman
1997 - 2003 F150
Nov 3, 2015 07:47 PM
carl2591
Jun 14, 2015 06:03 AM
NewXer
Aug 1, 2014 08:32 AM
fgials
Oct 13, 2010 03:08 PM
