Ammo reloading question
Old Nov 14, 2007 | 09:32 AM
5_labsownus's Avatar
5_labsownus
I reloaded for about 10 years and that was about 20 years ago. Now I am starting to reload again and have a question I have not found a good answer. Now I am getting back in to reloading.
Do you de-cap your brass before or after tumbling?
The reason I ask is back in the day I did not have much money and did not own a tumbler but a friend did. I took the cases to him for tumbling but never saw what he did and I can’t remember if the cases came back de-caped.
Rod
Old Nov 14, 2007 | 10:11 AM
jim henderson's Avatar
jim henderson
Guess it is preference and what kind of equipment you have.
My loading sets are mostly RCBS and Lee dies. All of them have a decapper in the resize die so I clean the cases first and then decap/resize. To decap with these die, the cases should be clean to start.
Probably doesn't make a big difference unless you are a competition shooter.
There are primer cup cleaning brushes and scrapers, but they take a lot of time. I use these once in awhile, but typically the cup isn't too bad and the pressure of the cap seater is usually enough to get the cap properly seated.
I load tens of thousands of rounds and have never had a problem with cleaning the cases with cap on. Only troubles I have had were with rocks.
Just my opinion,
Jim Henderson
Old Nov 14, 2007 | 11:34 AM
pitrow's Avatar
pitrow
I agree with Jim. I've tried it both ways, but it always seemed easier to clean them first, then decap.
Old Nov 14, 2007 | 11:50 AM
5_labsownus
That is what I was leaning toward and think I saw that it makes sizing easer with clean cases. That makes sense to!
Thanks
Rod
Old Nov 14, 2007 | 12:00 PM
TheWiz427's Avatar
TheWiz427
I De-cap all of my brass before i tumble them. Occasionally i have a piece of media in the primer pocket but thats no biggie.
Old Nov 14, 2007 | 12:14 PM
bczolone's Avatar
bczolone
I always de-cap first...I then have brass to make my measurements from so I can sort out all the rejects, but I reload for accuracy, not volume.
Old Nov 14, 2007 | 12:28 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Rod
Depending on what caliber I'm loading, it could be either. . . or both.
For most pistol cartridges, I tumble, then re-size and deprime, because I use carbide (sizing) dies.
For most rifle cartridges, I tumble the brass, then lube and size and deprime.
Then, before going to the next steps, I drop the lubed brass into a different tumbler (Lyman Turbo 1200) and using OLD media, I remove the lube from the cases.
IF I'm using once-fired military brass (with a crimped in primer) I use a Lee de-priming tool, which is nothing more than a hardened pin punch and a hardened shell holder, and using a mallet, drive the primer out of the cases.
Then tumble the cases.
Keith
Old Nov 14, 2007 | 09:47 PM
rlb454's Avatar
rlb454
I always tumble first, then start the process on a RCBS pro 2000 for auto rounds. Tumble first the use a single stage RCBS Rockchucker for rifle and .454 rounds.
scottddove
Mar 6, 2010 10:42 PM
Bruker
Sep 9, 2006 12:12 AM
Munkey
Dec 13, 2004 09:34 PM
thunderguns71
Oct 7, 2004 06:54 PM
