need some help
Old Nov 13, 2007 | 03:22 PM
factory594x4's Avatar
factory594x4
Question need some help
Sorry to cross-post
I ripped the transmission cooler lines out and burned up my tranny driving.
It's a Fordomatic 2 speed...it runs in low and reverses fine, but it won't shift into high gear. It only slips.
I got another transmission...a used one...for $250. I had to swap the front pump to fit the newer-model torque converter.
I've changed out the transmissions, but it still does the same old thing...is it the front pump that's doing this....or is this a common problem for Fordomatics?
I need to get it running. What's the quickest and easiest solution to my problem? Please, help.
Is the C-4 an easy swap? What do I need to make this happen?
'63 Fairlane
200 I6
2 speed auto
Old Nov 13, 2007 | 03:50 PM
cobraguy's Avatar
cobraguy
Sounds like the piston seals for the High gear clutch is leaking and not letting the clutch engage. IMHO that tranny is an expensive piece of doo doo. C4 is an easy swap and a better choice.
Old Nov 13, 2007 | 04:11 PM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
The clutches in the trans are out and or the pump or valve body needs to be replaced in in. I feel pretty sure that you can get this rebuilt.
we build converters even for that trans.
www.accperformance.com
any questions call 888-267-7464
nelson
Old Nov 14, 2007 | 01:13 AM
factory594x4
What do I need for a c-4 swap? Can I use the same torque converter? What year should it be from?
Old Nov 14, 2007 | 03:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First C4 = 1964, First Fairlane with a C4 = 1964. But, all the 1965/66 Mustangs 200's use a C4, and there's no shortage of 65/66 Mustangs. You'll prolly have to change the driveshaft.
Question? Are you certain your 1963 Fairlane has a 200 engine? It could be a 170.
5th digit in the VIN is the engine code: U=170 / T=200.
Mustangs made between 4/64 thru 8/23/1964 came with either a 170 or a 200 engine, and will a 170/C4 combination. After that date, all Mustang 6's are 200's.
Old Nov 14, 2007 | 08:12 AM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
Torque covnerter
If you need a custom built converter to help make it all come together for you, just let me know - 888-267-7464
nelson
