running wires into cab
Old 11-13-2007, 01:31 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
Question running wires into cab
I need to run some small gauge wires (led lights) from in front of the radiator to the inside of the cab for the power and switch...any ideas on the easiest way in through the firewall?
Old 11-13-2007, 03:17 PM
Rtfd406's Avatar
Rtfd406
Rtfd406 is offline
I mounted lights right behind my grill as well. I ran the wire back throuh the hood, down the back of the fire wall in between the fender liner and the fire wall. Drilled a small hole about an in up from where the floorpan turns up. Just be careful when drilling the hole you don't drill through the fender liner also. Put a grommet in the whole to protect the wires then used a silicone caulk to seal off the whole. This is the second truck I have used this method on. Works well.
Old 11-13-2007, 03:50 PM
black04lariat's Avatar
black04lariat
black04lariat is offline
There is a large rubber grommet right above/next to the gas pedal. On the inside it will be covered with a piece of foam (you will see the imprint of a circle on it). Rip is off and a rubber grommet will be behind it. Cut a slit in the grommet and feed your wires thru it.
Old 11-13-2007, 04:31 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
Great thanx for the input!
Old 11-13-2007, 05:56 PM
Fosters's Avatar
Fosters
Fosters is offline
yep, that'd be the hole for the clutch cable on manual cars; best place to pull a cable through.
Frankiea87
1999 to 2016 Super Duty
12-24-2011 07:21 AM
wwiprops
03-28-2011 07:34 AM
a2vwnick
06-06-2009 11:13 PM
djd
01-08-2002 01:02 PM
Quick Reply: running wires into cab
