Cap Brake Light
Old Mar 26, 2011 | 08:47 PM
wwiprops's Avatar
wwiprops
Cap Brake Light
Is there an easy way to wire a cap brake light from the rear of the truck or do I need to run the wire into the cab? Thanks, Scott
Old Mar 26, 2011 | 09:07 PM
woodnthings's Avatar
woodnthings
Yes, just run the wire down the hole in the enclosed area common to the taillight. I used a 2 prong connector so it is easily removable. Run the wires to the trailer brake light wire and a good ground.
Old Mar 27, 2011 | 12:22 AM
puller45's Avatar
puller45
Not trying to be smart a$$, but doesn't it blink with one of your turn signals ? I took mine to the brake light switch, maybe I didn't have to.
Old Mar 27, 2011 | 05:46 AM
wwiprops's Avatar
wwiprops
Thanks for the replys. I was concerned with the flashing as well. I would think the brake light would work but it would also flash when the appropriate turn signal is activated.
It is a long run up to the brake switch from the back of a crew crab!
Old Mar 27, 2011 | 06:13 AM
woodnthings
The trailer brake signal is just that a brake signal. You also have turn indicator wires in that harness too. There is a small electric unit that most canopy dealers have that allows you to wire it into the lights. You just have to get a wire to each side, then it requires an input from both sides before it will send an output to the third brake light. I have done it both ways, and both work fine.
Old Mar 27, 2011 | 07:02 AM
wwiprops's Avatar
wwiprops
Great, thanks.
Old Mar 27, 2011 | 07:27 AM
woodnthings
If you have any questions, take a look at THIS ARTICLE, it shows the basics on how to do it.
If you want to go the electrical box route, do a search for BRAKE LIGHT LOGIC BOX
Old Mar 27, 2011 | 12:58 PM
puller45's Avatar
puller45
Thats a very interesting article, as soon as it quits raining I'm going out to see if my F250 has that extra wire he describes, At 66 I still do learn something new every day. I also didn't know about the logic box, thanks for the info.
Old Mar 27, 2011 | 03:14 PM
SpringerPop's Avatar
SpringerPop
I just looked at the wiring diagrams for mine.
Sure enough, that light-green wire is shown, and it comes right off the brake light switch before it goes into the multi-function switch.
I'll verify it for myself later tomorrow.
Pop
Old Mar 27, 2011 | 07:51 PM
woodnthings
Got it for you Pop!
If you look up on the left side of the spare tire, you should see it. Has a heat shrink end on it.
Old Mar 27, 2011 | 08:09 PM
snakedoc's Avatar
snakedoc
x2 that wire is how i have me camper light run.
Old Mar 27, 2011 | 08:16 PM
DND58's Avatar
DND58
Perfect timing on the cap wiring question. I've found the green wire so that should work for the brake light. What are you guys doing for the 12 volt light for cap interior?
Old Mar 27, 2011 | 08:29 PM
woodnthings
I found a set of "Racing LED Driving Lights" at Wally World. They were $14. Slim line little lights, far from driving lights but great canopy lights. I just wired them to the parking lights circuit, so you have to have the lights on to make them work, but was a simple hook-up. I ended up using the cheesy rocker switch that came with the lights.
Old Mar 27, 2011 | 10:57 PM
SpringerPop
Slick-o-matic drive!
Gonna' have to use that good idea, Ken!
Thanks for the green wire photo, too!
How do the LED bars attach?
Pop
Old Mar 28, 2011 | 07:34 AM
woodnthings
Pop
They came with a thin metal bracket. So I just sheet metal screwed them into the metal frame of the window surround.
noddydon
2015 - 2020 F150
Nov 25, 2022 09:07 AM
00250SD
Jul 29, 2017 10:34 PM
jdlindz515
Aug 10, 2016 01:53 PM
whalerron
Aug 7, 2016 08:30 PM
fairlaniac
Mar 16, 2009 10:13 AM
