"Flipping"/relocating fuel filter?
Old Nov 13, 2007 | 01:27 PM
ghunt's Avatar
ghunt
Have any of you guys relocated the fuel filter assembly or flipped it on its bracket somehow?
I'd really like to run an intake from my turbo straight over to that big open spot on the passenger side fenderwell, but the fuel filter is smack in the way.
I figured it'd be easy enough to replace the hardlines with -4 AN line if need be since they aren't high pressure lines...just wondering what you guys have done for relocation
Old Nov 13, 2007 | 01:45 PM
starmilt's Avatar
starmilt
I don't see where you would have any problem. I changed the one on my 7.3 to the old style without water seperater because of cost of filters.
Old Nov 13, 2007 | 03:57 PM
ghunt's Avatar
ghunt
Well, I'd like to relocate it to the fenderwell or somewhere in that area, but I guess I'm a little worried about getting air into the system with the lines off.
Can regular teflon tape be used with diesel fuel?
Old Nov 13, 2007 | 04:08 PM
starmilt's Avatar
starmilt
yes air problem won't be any worse than changing filter. bleed at the schrader valve you should be ok.
Old Nov 13, 2007 | 04:10 PM
starmilt's Avatar
starmilt
yes air problem won't be any worse than changing filter. bleed at the schrader valve you should be ok. I like changing filter with motor warmed up easier to start and get rid of air.
Old Nov 13, 2007 | 05:57 PM
ghunt's Avatar
ghunt
Sounds good.
Also I guess I was a little mistaken about the lines, I looked and see they're probably more like a -6 AN.
But, I guess that's a project I'll be working on sometime before too long.
walterkurtz
24
Oct 5, 2012 07:36 AM
Intimnasc
Jun 15, 2012 07:08 AM
St_alfonzospancakebreakfa
Oct 13, 2004 08:50 AM
