Head gasket?
Old Nov 12, 2007 | 10:10 AM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
Head gasket?
I believe I have a bad Headgasket. And hopefully not a bad head or block. The miss has gotten has gotten from barely noticable and clears up, to noticeable. Here are the symptoms
Missing a little
Puff of white smoke upon startup (sweet smelling)
Leaking antifreeze near end of engine
Had to refill antifreeze recently >1 gallon
Low power
I have since garaged it and going to determine what to do.
Any good suggestions on headgasket replacement on a 99 Superduty (Late) I worry about the heatbox proximity to the passenger side head(I know it was tough when I did glow plugs earlier this year). Should I just get a gasket set off ebay? Do I have to replace injector orings (cheapest I found was 10 bucks a pop). Any other things to do while I'm in there
Old Nov 12, 2007 | 11:49 AM
santacruzf250's Avatar
santacruzf250
Bummer man. Can't speak from personal experience but you'd probably want to go with OEM head gaskets. If you're thinking of building the engine in the future for big power, thicker head gaskets and ARP head studs.
Old Nov 12, 2007 | 12:11 PM
Kwikkordead's Avatar
Kwikkordead
If you have a lift it's easier to pull the body and do it on the truck.
Or you could pull the front off, radiator and all, then have enough room to get in there.
Those heads are heavy enough to require a cherry picker to lift in and out without straining your back.
Old Nov 12, 2007 | 03:16 PM
santacruzf250
If you're not to into fabbing, there are cylinder head removal tools/hooks on ebay for under $10. Kwik is right about the heads. It take two people to remove if you don't have a cherry picker.
Old Nov 12, 2007 | 03:40 PM
SVLERF250PWRSTRKE
too bad there not aluminum like the 6.OH's
Old Nov 12, 2007 | 04:23 PM
dagnuten's Avatar
dagnuten
Originally Posted by SVLERF250PWRSTRKE
Missing a little
Low power
You sure it's not just an injector o-ring?
would cause the slight missing, white smoke, low power, and lost antifreeze.. not sure about the leaking antifreeze though....
Old Nov 12, 2007 | 10:15 PM
SVLERF250PWRSTRKE
I'll check the o-rings as i remove the injectors. I do have an external loss of antifreeze coming from the passenger side of the motor. Heater lines all look good.
Old Nov 12, 2007 | 10:47 PM
santacruzf250
how many miles does your engine have? Has the motor had a tough life?
Old Nov 13, 2007 | 06:39 AM
Kwikkordead
They are known for cracking the block around the middle freeze plug behind the starter.
Old Nov 13, 2007 | 11:20 AM
SVLERF250PWRSTRKE
215k , not too bad of a life , Don't pull with it too often
Old Nov 13, 2007 | 01:05 PM
1996pwrstrk's Avatar
1996pwrstrk
I would check for a crack in the block first as Dan said. I have seen three that have cracked so far.
Old Nov 13, 2007 | 01:37 PM
santacruzf250
Compression Check?
Old Nov 14, 2007 | 12:14 AM
Kwikkordead
Are you the one that helped Cookie pull those engines last year? Or did he help you?
I've seen the crack myself on an old IDI that the owner brought by for me to look at. Pour water in the radiator and watch it run right out on the ground. Just bought the truck and was really taken.
Old Nov 14, 2007 | 12:46 AM
1996pwrstrk
Yeah Scott and I started out helping our chapter leader pulling out those two PSD's out in about 12 hrs. Then we had to do Scott's because of a cracked block and just recently I found a 2000 F250 with 215,000 miles on it for my uncle but the engine only has 49,000 because it had a cracked block.
Old Nov 14, 2007 | 12:30 PM
SVLERF250PWRSTRKE
my dad may have an old 7.3 block , like late 80's would it be the same ? I know the heads are different
