300 bellhousing, what motors will bolt up??
I'd stay with the 300.
I'd stay with the 300. any engine from 65 to 96 will bolt up. so all you need to do is find a good engine and swap over any parts that are needed. if power is what you want check out cliffordperofmance.com , jegs and summit racing for performance parts. you can also get a custom ground cam, lifter and rockers through comp cams. you will be pushing some horsepower and better torque numbers than a v8 and still have the strength of Fords greatest straight 6.
F100Mann
08-30-2017 10:44 AM
56 f100 long
03-16-2016 02:39 PM
200, 300, 351, 49, bell, bellhousing, bellhousingfor, bolt, f150, ford, housing, inline, interchange, straight, windsor
