1974 F100
Old Nov 11, 2007 | 07:35 PM
knash0727's Avatar
knash0727
1974 F100
I have a '74 F100 with a 390 V8 that has run before, and it ran good. Now it will not fire. Sometimes it will, but it will die while ideling. It is getting pleanty of fuel, you can smell it flooding, but it wont crank. I have replaced the Distrubitor cap, rotor, and the wires. What could it be?
Old Nov 11, 2007 | 07:43 PM
skosler's Avatar
skosler
take a plug out and then stick the wire on it and ground the threads to metal. jump the solenoid and you should see a spark. if you do then at least you know you are getting spark. the only other thing it could be is either the timing of the spark or too much fuel.
Old Nov 11, 2007 | 08:27 PM
knash0727's Avatar
knash0727
I am not getting spark. why could that be?
Old Nov 11, 2007 | 08:44 PM
scottie2hottie's Avatar
scottie2hottie
points or electronic distributor?
Old Nov 11, 2007 | 09:22 PM
skosler's Avatar
skosler
okay I'm just gonna say it because I'm not sure if you know it or not. When I say jump the solenoid, I mean start it from under the hood.
If you have no spark then check the plugs and wires with a multimeter. if those are good then it's probably the distributer/cap/rotor.
Old Nov 11, 2007 | 10:08 PM
Mil1ion's Avatar
Mil1ion
: ....Now it will not fire. Sometimes it will, but it will die while ideling. It is getting pleanty of fuel, you can smell it flooding, but it wont crank
So the topic of the thread is actually " engine won't crank"?
Please put the actual topic in the title of threads
Always have a freshly fully charged battery before testing.
Check the battery,cables,starter solenoid,and starter.
Use the jumper wire to bypass IGN switch.
If it still won't crank.. try another good battery
Your replaced ignition parts have nothing to do with the engine cranking.
Old Nov 12, 2007 | 07:34 AM
skosler's Avatar
skosler
I think he meant it won't fire up. I try to use turn over or spin up instead of crank. Crank could mean crank up (as in start up and run) or it could mean crank over (as in turn over)
Old Nov 12, 2007 | 01:18 PM
Mil1ion's Avatar
Mil1ion
There is crank ie: starter engages and cranks the engine
then there is..... Start and RUN.
2 different things.
That's why the TITLES should have the actual topic in them.
Old Nov 13, 2007 | 12:05 PM
ChaseTruck754's Avatar
ChaseTruck754
some people don't know the difference though, and will just say what they have heard before...
73f100rangerguy
Jun 11, 2011 04:30 PM
beartracks
Sep 29, 2010 12:36 PM
petz_83_f100
21
Oct 2, 2007 06:08 PM
NDspeed
13
Jun 30, 2005 07:02 AM
53f100ala
Jun 3, 2004 09:07 PM
