not original engine, please help
Old Nov 11, 2007 | 05:30 PM
J L Lilly's Avatar
J L Lilly
Just bought winter project need id on engine
On sticker on valve cover 460"B"(2cv4)
DZVE-9C485-JA
I'm kinda new to the 429/460 thing so I need help, thanks
JL
Old Nov 14, 2007 | 03:27 PM
rjvaughan's Avatar
rjvaughan
DZVE doesn't make sense .. the 2nd char should be a number .. could it be a "2"?
The D means 1970's .. the second number is the year within the decade that the design was introduced (not necessarily manufactured).
The "V" means Lincoln usage.
You need to look on the block itself near the back for a code. Should be D1VE (1971 - 1979) or D9TE (1979 - 1997) if a 460. Not sure of all the 429 codes.
I found out my 460 was a D9TE design because I first noticed the weighted crank spacer behind the harmonic balancer, then I saw a D9TE part number on the balancer itself.
Old Nov 14, 2007 | 03:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DZVE-9C485-JA
JL
Welcome to FTE
Where exactly did you find that number? It isn't on the engine block, because a 9C485 is part of the smog pump system.
The engine block casting number is either: D1VE-6015-AB or D9TE-6015-AB.
rjvaughan: A V doesn't necessarily mean Lincoln usage, a part number prefix with a V in it could fit anything. Example: D4VZ-6316-A .. Vibration Damper fits all 1973/78 passenger car w/ a 429/460 engine.
Old Nov 14, 2007 | 04:01 PM
rjvaughan's Avatar
rjvaughan
Right you are .. I realize now that I worded that badly. The "V" just means it was originally designed for the Lincoln line, or "debuted" there .. right? Just like "T" is truck and "Z" is Mustang .. again doesn't mean it won't appear in other vehicles.
Old Nov 17, 2007 | 10:31 PM
J L Lilly's Avatar
J L Lilly
numberdummy,
The number, is on a sticker , on the valve cover on the drivers (left) side of the engine.
I guess I was most curious about the "460(B)2c4v" . I was under the impression that 4V was a 4bbl thing , but this thing has a 2bbl.
Oh, the sticker also says it meets 1977 epa standards for passenger cars.
Thanks
JL
Old Nov 18, 2007 | 01:22 AM
Bear 45/70's Avatar
Bear 45/70
Well there were never any 2 barrel 460s so it must be a 429.
mcintoc
13
Aug 11, 2022 06:21 PM
AmongHidden
Mar 31, 2014 10:46 AM
Bkcochran
Mar 22, 2013 10:29 AM
Northern Caveman
1978 - 1996 Big Bronco
Apr 19, 2012 06:11 PM
cecil
13
Oct 12, 2001 02:23 PM
