Where is the baro sensor?
Old Nov 11, 2007 | 02:34 PM
dirtworker's Avatar
dirtworker
Hey fellas can someone point me in the right direction? It's an 03
Old Nov 11, 2007 | 04:30 PM
18vtx00's Avatar
18vtx00
it is not alone, it is made into the MAP.
Old Nov 11, 2007 | 06:11 PM
dirtworker's Avatar
dirtworker
10-4, thanks
Old Nov 11, 2007 | 06:12 PM
dchamberlain's Avatar
dchamberlain
I have an 04. I don't know if it's in the same place as on 03. On the 04, it is behind the removable panel below the steering wheel, at the bottom attached to the panel support.
Old Nov 11, 2007 | 06:19 PM
dirtworker's Avatar
dirtworker
dchamberlain, i have one of those, how common is it as far as failures
Old Nov 11, 2007 | 06:35 PM
dchamberlain
I really don't know. Mine has not failed, but I've only had the truck for a month or two. Are you having a problem that makes you think it's failed?
Old Nov 11, 2007 | 06:49 PM
dirtworker's Avatar
dirtworker
I have an intermittent surge. I went to ford and they suggested an icp and connector, I replaced those with no results. My egr has been unplugged for a while so I've ruled that out. I've also replaced the ipr, like ford suggested. This things out of warranty so all of this comes out of my pocket. I don't know what my next move should be, any suggestions?
Old Nov 11, 2007 | 07:14 PM
fomoconut's Avatar
fomoconut
What about the exhaust sensor (backpressure)? Do you know if your truck has the most current flash? I believe the most current flash disables this sensor.
Old Nov 11, 2007 | 07:27 PM
dirtworker's Avatar
dirtworker
I had it flashed about 2 months ago, I don't know if its the latest. Over the last year I've replaced the maf, map, oil temp, and ebp. I've checked the placed that on the harnesses that are subject to chafing and found one chafe, fixed the chafe but not the problem. It shows no codes and ford doesn't know what else it could be. I'm scared to drop it off and say "just fix it", because it has no warranty and the hourly rate gets expensive quick.
Old Nov 11, 2007 | 07:38 PM
fomoconut's Avatar
fomoconut
Wow you have replaced lots of stuff. My truck surges and/ or stalls only once a month. Ford replaced the turbo but of course that didn't help. I actually lost 3lbs of boost w/ that. I know its an electronic deal some where but nobody can find it. Have you tried the black box from Ford yet ?
Old Nov 11, 2007 | 07:46 PM
dirtworker's Avatar
dirtworker
I haven't tried the black box yet, ford has hooked their computer to it while it was surging and the two guys just stared at it with a WTF look on their face. They don't have any answers and are out of suggestions.
Old Nov 11, 2007 | 07:51 PM
denman81's Avatar
denman81
is it a full time surge? when your stopped dose it surge and then the idle drop down kinda low? give us a little more detail if you can. do you have a tuner?
Old Nov 11, 2007 | 08:02 PM
dirtworker's Avatar
dirtworker
It surges more often than not. It will do it hot or cold, and alot of times it doesn't want to return to idle when I'm stopping it wants to hang around 1000 rpm for a few seconds. no tuner
Old Nov 11, 2007 | 08:04 PM
denman81's Avatar
denman81
When you accelerate dose the engine do kind of a quick miss?
Old Nov 11, 2007 | 08:07 PM
dirtworker's Avatar
dirtworker
Quick miss? Like a hesitation? Or injector not firing?
