351M Timing Pointer ????
Old Nov 10, 2007 | 10:08 PM
JCoggin's Avatar
JCoggin
Where is the timing pointer suppose to be located on the 351M? Mine was missing when I bought the truck so I don't know what I need to be looking for in the way of a new one.
Thanks,
James
Old Nov 11, 2007 | 12:02 AM
roger dowty's Avatar
roger dowty
i can try to get a pic to you tomorrow..it's located on the passenger side of the pulley/balancer using bolts towards the bottom of the water pump. I think it uses bolts that secure the water pump to the block...pretty sure.
Old Nov 11, 2007 | 05:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Looks to me like it bolts to the passenger side of the engines front cover plate.
Since the OP didn't list the information regarding the year and model the pointer is needed for (profile sez 1974 Bronco which didn't come with a 351M), I can't even begin to post the part numbers.
NOTE: Numbers: There are 5 different pointers used, it depends on the year, where the vehicle the engine is from was sold new, whether it had or has EEC, with or without A/C. Install the wrong pointer, what will be the result? Timing off.
Old Nov 11, 2007 | 09:44 AM
JCoggin's Avatar
JCoggin
1979 Ford Bronco Ranger XLT
351M
PS
AC
Need timing pointer.....
JC
Old Nov 11, 2007 | 12:58 PM
NumberDummy
Originally Posted by JCoggin
1979 Ford Bronco Ranger XLT 351M PS AC Need timing pointer.....JC
D3AZ-6023-A .. Timing Pointer ~ Fits all of the following except CA: 351C 2/4V = 1973/74 Ford passenger cars / 351M/400 = All FoMoCo passenger cars 1975/79 / 1977/82 F100/350's / 1978/82 Bronco's / 1980/82 Econolines.
D7AZ-6023-B .. Timing Pointer ~ 1977/82 351M/400 Cars & Trucks = CA only.
Both the above p/n's are obsolete.
How do you tell if a vehicle was sold new in CA?
Look on the Rating Plate for the DSO code.
If the code is 71 or 72 = the Ford vehicle was sold new in CA.
Lincoln/Mercury CA DSO code: 52.
Old Feb 25, 2008 | 01:28 AM
brthevio's Avatar
brthevio
Are those ford pn#'s I have a 351m without the timing pointer also. Thanks for the info.
Old Apr 3, 2011 | 11:49 PM
KingCrew's Avatar
KingCrew
351C Timing Pointer
[quote=NumberDummy;5328395]D3AZ-6023-A .. Timing Pointer ~ Fits all of the following except CA: 351C 2/4V = 1973/74 Ford passenger cars / 351M/400 = All FoMoCo passenger cars 1975/79 / 1977/82 F100/350's / 1978/82 Bronco's / 1980/82 Econolines.
Sir,
I'm trying to find and catalog for a '70-71 351C block, D0AE-L ("M"-code, "1E11" date code):
1. Correct Timing Pointer
2. Front sump oil pickup (stock)
Your help will be appreciated!
PI
Old Apr 4, 2011 | 10:07 AM
KingCrew's Avatar
KingCrew
Sir,
I'm trying to find parts and catalog numbers for a '70-71 351C block, D0AE-L ("M"-code, "1E11" date code):
PI
Old Apr 4, 2011 | 04:55 PM
smokeyb97's Avatar
smokeyb97
Thanks,
James
Does this help?
fordno1
Jun 14, 2025 12:24 PM
Odisvan
Jul 5, 2016 10:13 AM
mawagian
Oct 18, 2015 04:41 PM
mnewbolds
Sep 15, 2014 05:19 PM
E Mattias C
Jul 30, 2012 06:28 AM
