Help! Help!
Old Nov 10, 2007 | 05:52 PM
ebtrucker's Avatar
ebtrucker
Question Help! Help!
I have a 75 F-250 and tuned it up was running great, until when I was changing the fuel filter it broke it broke off in carb when removing it ( Fram made in China). With a 32 year old carb I decided to replace with a rebuilt. I bought a remaned unit over the internet. I would have rebuilt mine but didn't want to extract filter. My problem is it will start and die. I've set mixture screws 1, 1 1/2, 2, 21/2, 3 turns with no eval. Took off air horn started and checked float, reset float to specs a couple times even though it did not need it. Then at dark I noticed with air horn off it just leans out after a few seconds, but if you excelerate or pump throttle it floods. Will resart and do the same thing. This family truck ran for 32 yrs. can someone help?
Old Nov 10, 2007 | 06:06 PM
ebtrucker's Avatar
ebtrucker
By the way this is a 2100 on a 360 motor! Please reply Thank's
Old Nov 10, 2007 | 07:15 PM
rusty7983's Avatar
rusty7983
buy a screw extractor from a hardware or parts store. they are a few bucks. you tap it with a hammer and as you thread it it backs the piece out. i used to do the same on my snowplow, i would hit stones the plow would pop up and break the couplers on the lines off. i used to keep the tools and spare parts in the truck. return the rebuilt and buy a rebuild kit.
Old Nov 10, 2007 | 07:49 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site!
Please read post #1 of this thread.
https://www.ford-trucks.com/forums/1...ease-read.html
Also, Maybe check in the fuel delivery forum where the carb experts are.
sounds like a metering problem tome
Old Nov 10, 2007 | 09:31 PM
ebtrucker's Avatar
ebtrucker
Thanks, I had to use old carb for core. and thank's I'll check that forum also!
Smellii
Dec 28, 2012 05:50 PM
mh34444
Sep 27, 2009 03:24 PM
robv60
Oct 4, 2004 08:16 PM
RaleighDad66
25
Aug 30, 2004 08:25 AM
mvtofino
Feb 7, 2004 04:27 AM
