Sponsored by: Real Truck
? on Bilstein shocks
Old Nov 10, 2007 | 04:38 PM
FORDDIEHARD's Avatar
FORDDIEHARD
Just a quick question regarding the rear shock options for a 2000 F-250 Crew Cab Lariat, standard height 5.4 motor. Bilstein shows 2 numbers that will fit this application: BE5-C296-HO AND BE5-2819-HO is there any difference in these 2 shocks?
Thanks in advance,
Tim
Old Nov 10, 2007 | 05:45 PM
boxcar1974's Avatar
boxcar1974
The shocks for the front and rear are different. C292 are the 4wd rear and the 2819 is 4WD front.
Old Nov 10, 2007 | 06:24 PM
FORDDIEHARD
According to Bilstein BE5-2818-HO is for the front of a 2000 F-250 superduty crew cab 4WD and BE5-C296-HO or BE5-2819-HO are for the rear. Just was wondering what the difference between the 2 rear ones were?
Thanks
Tim
Old Nov 10, 2007 | 06:34 PM
blackhat620's Avatar
blackhat620
Thanks in advance,
Tim
For Standard height, Bilstein rear shocks
99-07 SRW F250/F350 SD 2WD use BE5-2816-HO
99-07 DRW F350 SD 2WD use BE5-2816-HO
99-07 DRW F350 2WD Chassis Cab use B46-1329
99-04 SRW F250/F350 SD 4WD use BE5-2819-HO
05-07 SRW F250/F350 SD 4WD use BE5-C296-HO
99-04 DRW F350 SD 4WD use BE5-C296-HO
99-04 DRW F350 4WD Chassis Cab use BE5-C342
Old Nov 10, 2007 | 06:38 PM
boxcar1974's Avatar
boxcar1974
Cant say for certain but if I remember right when I stalled mine they were two different lenghts. The rears have a firm plastic sheath/boot and the fronts have a flexible rubber boot.
donovan
6.7L Power Stroke Diesel
Jul 26, 2016 06:08 PM
FSJ-EARL
38
Jul 13, 2010 02:18 PM
OverHeight
Sep 9, 2009 03:05 PM
Budman1962
Feb 9, 2008 12:38 AM
swengle
Oct 25, 2006 02:27 PM
