300 I6 and 302 computers the same?
Old Nov 9, 2007 | 06:18 PM
justin_jkj's Avatar
justin_jkj
i have an 89 f150 with a 300 and a 89 f150 with a 302 parts truck with a 302 are the computers the same in these trucks or are they diffrent?
Old Nov 9, 2007 | 06:21 PM
Silver Streak's Avatar
Silver Streak
Yes and no. They are physically the same size, they use the same connectors and the pin outs are the same. The software inside is different. It is entirely possible that the 302 computer will allow the 300 to start and run, in fact it probably will. How well it will run is anybody's guess.
Old Nov 10, 2007 | 08:45 PM
Eddiec1564's Avatar
Eddiec1564
The 300 with a 302 ECU runs,but thats about it. no power, lots of pinging. I think the 302 ECU places more timeing advance than a 300 ECU. But it got me home though! Also make sure you get a ECU to auto or manual tranny to match what tranny you have, the Automatic tranny ECU do not like clutching actions.
Old Nov 10, 2007 | 09:16 PM
Silver Streak
The 302 computer probably ran poorly because it was too lean. The 302 computer is setup to add fuel through 8 injectors, so it has shorter pulse width. After a few hundred miles it would probably wise up and run a lot better, but I doubt it would ever be right.
Old Nov 11, 2007 | 04:30 PM
Eddiec1564's Avatar
Eddiec1564
You may be right about the fuel, but both engines are MPI so two missing injectors may not affect the fuel ratio. More likely the 300 runs around 55PSI on fuel rail and 302 is about 35?PSI So that may be the problem. But in a pinch it ran enough to get home! Later I got a auto tranny ECU for the 300, mine is manual, quicky found out the programming of ECU's are diffrent for manual to automatic trannys. the automatic ECU don't like being lugged under 1200RPMs
