90 f250 hd 4x4 chass 65cab 85 300 6cyl .30 over efi ex clifford heated intake
2bbl planning to build have all but cab moter in shop tore down ready for trip to machine shop chassis has 410s rear is full float do i need to go with bigger cam
is balancing worth extra $ will run universal cat with flowmaster muffler will 2.5inch piping be right sorry first post is this lame trying to get things going
Reason: more info
It depends...to what use are you going to put your truck? What carb? The cam builders can give you advice and options on cams depending on your intended use of your vehicle. Comp, Isky, Crane, Reed, Schneider...
