SYNC help
Old Nov 9, 2007 | 12:25 PM
dkderm's Avatar
dkderm
SYNC help
I just bought a 2008 Sport Trac with Nav and SYNC. It's awesome! All of the features work well except my address book from my phone (Samsung Blackjack) doesn't download to my SYNC. Is there a way to manually enter names/numbers into the SYNC computer address book?
Thanks for your help!
Old Dec 19, 2007 | 05:31 PM
SYNC_fan's Avatar
SYNC_fan
Blackjack SYNC name entry
Hi dkderm,
The Blackjack doesn't support automatic phonebook download. But, you can send individual contacts using the Blackjack. Here is how:
On SYNC:
Select Modify Phonebook
(this is either under Phone Settings or Advanced depending on which radio type you have)
Then select Add Contacts
On your paired Blackjack:
Select "Contacts" from the homescreen
highlight the contact you wish to send
press 'Menu' ->3 Send Contact ->1 Beam
The 'Beam' menu will show the SYNC device. Select it and you'll see the display change to 'pending...' and then 'Done'.
'Done' indicates that the contact has been sent. You should notice that the count on your SYNC increases by '1'. You can repeat the Blackjack instructions above until you have sent all of the contacts you wish to have stored in your SYNC.
Old Dec 19, 2007 | 07:27 PM
dkderm's Avatar
dkderm
thanks for the help! once the contacts are beamed, can they be edited from the sync touch screen?
Old Dec 19, 2007 | 09:05 PM
SYNC_fan's Avatar
SYNC_fan
The contacts must be edited on the phone prior to sending them to SYNC. You can delete individual contacts from SYNC under 'Modify Phonebook' incase you want to remove a single contact and/or send a freshly edited version of a contact from your phone.
hammer65
Ford In-Vehicle Tech
Apr 27, 2015 08:16 PM
glruff
Aug 13, 2013 08:24 AM
KC8QVO
Jan 28, 2011 05:44 PM
Fishhawk460
2009 - 2014 F150
39
Jul 11, 2010 06:02 AM
