For the record, my 2001 V10 came with stainless studs from the factory.
What appears to be the problem is the nuts themselves corrode/weld themselves to the manifold. As the manifold expands and contracts from heating and cooling, it drags the nuts with it. And eventually breaks the studs.
It appears the studs themselves are defective from a bad heat treating process, where the shoulder is built up is where they are heated and compressed lengthwise. This is usually where they break. Although in my case, there were two that broke down in the head, nowhere near the shoulder.
Kinda like the old FE series engine manifolds cracking. Same cause.
The nuts on the studs I got out are rusted much more than the studs themselves. The studs look brand new and shiny, but the nuts are rusty and look like crap.
The studs the dealer sells per tsb are copper coated stainless totally non magnetic..
Dick
If thats true it makes absolutly no sense. In order to be a completly non magnetic stainless steel it will have to be a high alloy stainless, thus will not rust at all. Why copper coat them. A .0008" thick layer of copper is going to do nothing but prevent corrosion, which on a high nickel, chromium content stainless makes no sense because it is highly rust resistant.
Most stainless steel bolts on the market sold in hardware stores are made of 18-8 stainless steel which still has a very mild magnetic attraction. There are bolts made of 304 and 316 stainless as well but there cost considerably more.
I also don't see how anyone could ever rust through a set of cast iron manifolds either. Most are at least .500" thick. Hell the set of cast manifolds were on my 74' F-100 when I bought it and they were over 26 years old then.
The reason they coat them is they are going into aluminum. Its a corrosion thing. The nuts that they spec'ed out were supposed to be stainless but were highly magnetic..
I spent many threads talking about this topic in the past I'm not making this stuff up.
I even have the tsb and the part numbers somewhere..
