fuel injectors not working
Old Nov 9, 2007 | 08:03 AM
hotshot414c's Avatar
hotshot414c
Question fuel injectors not working
1989 f250 351w. i just swapped out the motor. now it wont start i have spark and fuel to the rail and timing should be good. the injectors arent opening. ive been reading other posts and ive tried 2 different distributors. and the ecc was just replaced before the engine swap and worked fine. i have 12 volts to injectors. apparently im not getting a ground from the computer. what should i do now. help would be greatly appreciated thanks
Old Nov 9, 2007 | 04:22 PM
mhg's Avatar
mhg
www.fordfuelinjection.com
they have all the test procedures
Old Nov 9, 2007 | 06:21 PM
subford's Avatar
subford
Sounds like you left the small black wire with a green stripe off at the NEG post of the Battery.
Old Nov 9, 2007 | 08:40 PM
hotshot414c
thanks for the input i checked the grounds and they are hooked up. i was looking around and i seen a chipmunk or mouse had been nesting under the upper intake. i guess i should pull the intake and check for chewed wires on the harness. i can see most of them and they look alright if one of the wire were chewed threw would that make them all the injectors stop working.
boj760
Dec 1, 2012 02:59 PM
Roy C
Aug 8, 2012 07:19 PM
jwolfe60
Jul 3, 2008 05:35 PM
coldnorthpole
Mar 3, 2007 07:19 AM
SoccerFetus8
Feb 22, 2007 11:46 AM
