More oil problems
Old Jul 13, 2002 | 10:31 AM
FordPerf300's Avatar
FordPerf300
More oil problems
Well, i replaced the oil pan gasket again lastnight, looked beautiful when i put it in. Filled it up with oil and started it, and let it run for a while, and it appeared to be leaking from the SAME spot again(this is where i started running around pulling my hair out) After that and saying a few swears at the the relentless oil pan gasket, my friend had spotted a stream of oil comming from up higher on the block (drivers side) the oil looked as tho it was leaking out from some sort of plate on the side of the engine and made it look like the pan gasket was leaking. Could someone tell me what that plate is for.
Old Jul 13, 2002 | 12:36 PM
DrFord's Avatar
DrFord
More oil problems
the plate you are refering to is covering your lifters. there is nothing to this just another gasket to replace. it is just a little harder to get to.
Old Jul 13, 2002 | 12:42 PM
FordPerf300
More oil problems
thanks, i'll have to get cracking on that soon, this board has been great
Old Jul 22, 2002 | 12:32 PM
FordPerf300
More oil problems
Well I went and looked at what i needed to do to remove the plate..I know that the powersteering pump and brackets have to be removed, maby the coil.. but i'm not to sure, has anyone ever done this and what is involved in doing this job, any help would be appreciated.
Old Jul 22, 2002 | 03:35 PM
wildjon300ci's Avatar
wildjon300ci
More oil problems
Nope, you don't have to remove that.....on my '85, the only thing I have to remove is the coil and bracket.......3 bolts and a wire....When you change the gasket, get a rubber one and silicone it to the lifter cover and let it set for an hour to let the silicone adhere to the cover and dry...don't put any silicone on the head side of the gasket......I tried that 3 times :-X11 and I couldn't get it to work (I'm VERY stubborn)
I'm out
Old Jul 23, 2002 | 10:31 AM
FordPerf300
More oil problems
[updated:LAST EDITED ON 23-Jul-02 AT 11:32 AM (EST)]Do the rubber ones last longer and seal better because I just purchased a cork gasket from ford before reading your post. If thats the case i'll return the cork one and pick up a rubber one.
Old Jul 23, 2002 | 01:45 PM
TallPaul's Avatar
TallPaul
More oil problems
Pkupman82
Dec 30, 2016 04:59 PM
mototrig
Sep 25, 2014 05:13 PM
JetFuelBurner
Jan 9, 2013 05:58 PM
rmford
Dec 9, 2011 11:28 AM
ejolliffe
Jun 11, 2007 06:26 PM
