Radiator support cage nuts?
Old Apr 8, 2016 | 11:32 AM
matt2491's Avatar
matt2491
Does anyone know where I can find the special rectangular cage nuts/clips that go in the bottom of the radiator support? It takes five of them. They look a little different from your average square cage nut.
Old Apr 8, 2016 | 12:12 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Do you think they look something sort of like these? These are also used on the floor of my 4x4 trucks for the plate that covers the transmission area. My 2x4 truck is an automatic so no removeable cover there, but I do believe these are the same clips.
Old Apr 8, 2016 | 03:22 PM
matt2491's Avatar
matt2491
Those look exactly like the clip/nuts that go in the support! Do you have a part # or source for them? And I wonder how those are installed...
Old Apr 8, 2016 | 03:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1TZ-16B166-G (replaced C1TB-16B166-A & C & E; C1TZ-16B166-E) .. Cage Nut - 1/2" -20 x 1/2" thick / Obsolete
1961/65 F100/250 4WD / 1961/66 F350/600 / 1965/66 F100/250 2WD / 1966 F250 4WD
No Ford dealer or obsolete parts vendor has any.
C1TZ-16B166-E =
MILLER OBSOLETE PARTS in Binghamton NY has 4 = 607-722-5371.
Shown as 16B166 in pic:
Old Apr 8, 2016 | 04:15 PM
TA455HO's Avatar
TA455HO
Lead Gopher
C1TZ-16B166-E =
No, I don't think that is them.....but I do see the correct part number in the drawing, I believe. I'll let the OP chime in to make sure we are looking at the same thing.
Old Apr 8, 2016 | 04:42 PM
matt2491's Avatar
matt2491
TA455HO, the ones you pictured are definitely them. I was able to pull a mangled one out of an old support and it is the same. Do you know where I can find these nuts?
Old Apr 8, 2016 | 05:15 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Bill may know of some available NOS that I can't access....
Look to Illustration Section 82 - Page 2 and that will hone in on the part number. Used in a few places.
359218-S2
NOS sources I know of are completely dry as far as this part goes.
But, they are close to this I believe.
https://www.amkproducts.com/bulk3.asp?part=B-12035
Old Apr 8, 2016 | 05:20 PM
TA455HO's Avatar
TA455HO
Lead Gopher
It also looks like NPD would normally carry this but is out of stock right now.
https://www.npdlink.com/store/produc...-167544-0.html
The cage just snaps into the opening and the wings are on the backside to keep the nut from pulling through.
Old Apr 8, 2016 | 05:28 PM
NumberDummy
359218-S2
Not listed under 16138 radiator support.
rearcounter & PartsVoice: CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
On rearcounter, DC's description is cage BOLT.
Old Apr 8, 2016 | 06:04 PM
TA455HO's Avatar
TA455HO
Lead Gopher
No, they don't have any, not even those 2. I can guarantee it.
Old Apr 8, 2016 | 08:06 PM
6t6merc's Avatar
6t6merc
I got some years ago at a fastener specialist store. If you live in a large community you can probably find a store like that.
Eric
Old Apr 8, 2016 | 08:16 PM
P38fighter's Avatar
P38fighter
clipsandfasteners.com carries these as does AuVeCO - not an exact copy but very serviceable. they are cage nuts
Old Apr 8, 2016 | 09:46 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I researched a bit further and these should be exact duplicates. They are listed on the official book of fasteners right next to one another.
5/16-24 1.06" OAL .78" Width - 359218-S2
5/16-24 1.06" OAL .78" Width - 377998-S2
It at least gives you a reference to check sizes at other vendors.
Old Apr 8, 2016 | 09:52 PM
matt2491's Avatar
matt2491
That's great! Thanks so much for the help guys. These nuts sure aren't cheap. Gotta pay to play though.
Old Apr 8, 2016 | 10:32 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Ya, AMK Products has a minimum $30 order, too. Check around and you might be able to get them cheaper. The NOS ones I got some time ago were $1 a piece.
