Wierd problem....
Old Jul 30, 2002 | 02:36 PM
ringkong's Avatar
ringkong
Wierd problem....
lets get the specs out of the way first.
88 F-150
4x4
4.9l
t-18
all right, I have this wierd execleration problem.
When I step on the gas, it will kind of hang(it doesn't die or anything, just kind of "waits"), man this is going to be hard to explain. when I excelerate the rpms will stay the same and the truck will feel like it bogs down, then all of the sudden it will have power and I will feel the push in my back, I won't move the pedal during this time. I know that probably didn't make sense, but any help would be greatly appreciated.
thanks.
Old Jul 30, 2002 | 07:35 PM
topo4u2's Avatar
topo4u2
Wierd problem....
Hello, when you say "step on the gas" do you mean to the floor or half way or what?
I think I know what you are talking about but a diagnosis may be a bit difficult. How long has it been doing these?
It could be a number of things that come to mind. Are you having any other trouble besides this? Let me know and will try and help.
Old Jul 30, 2002 | 08:02 PM
sty_69's Avatar
sty_69
Wierd problem....
Start the inexpensive way , change your gas filter , then check your fuel pumps .. you have one in the tank , one on the frame , drivers` side .. get your fuel pressure checked by a shop or a friend .. if all checks out , then I say reset your ecm by disconnecting the battery for five minutes , re-connect , then hold idle at 2000 rpm for 30 seconds , 1500 rpm for 30 seconds , then let idle on it`s own , then add fuel injector cleaner , and drive for a while on the highway.
If none of these helps , then try cleaning your MAF (mass air flow sensor) on your air intake. A dirty MAF sensor will also cause what you describe , my wife`s FORD car did the exact same thing , and the MAF was dirty..
Hope this helps!
Peter
1988 F 150 I6 4spd. man. Borg-Warner tranny , 3.73 rear end , towing a 3000 + pound trailer , with no trouble!
Old Jul 30, 2002 | 08:50 PM
65inline6's Avatar
65inline6
Post Wierd problem....
That actually sounds like you could be running lean/rich. The best(and easiest)way is to pull one of your spark plugs. If the ground is black, then you're running rich. If it is white, then you're running lean. If it is another color, then it isn't that. I know this from experience.
Old Jul 30, 2002 | 08:54 PM
MustangGT221's Avatar
MustangGT221
Wierd problem....
There is no mass air flow sensor on his 88'. They didnt even start putting them in until 94, and that was on California equipped emissions vehicles with a V-8 and automatic (i think). Then in 95 they put them on some V-8s with automatics. Then in 96 I believe most of the V-8s got them and California equipped I-6's got them. I might be off, but I think i'm close.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
Old Jul 30, 2002 | 09:57 PM
tetraruby's Avatar
tetraruby
Wierd problem....
Sounds like the clutch is slipping???
Old Jul 31, 2002 | 01:12 PM
ringkong's Avatar
ringkong
Wierd problem....
I press the pedal just enough to start going faster and no more.
if I floor it, no hesitation at all.
I thought about the clutch slipping too. but I replaced the clutch and pressure plate 1 month ago, and it doesn't do it when I floor it.
Sometimes it will stumble just cruising down the street to
and One more thing, which maybe a Ureka moment for some of you. Sometimes it is more pronounced(the stumbling that is) when it is wet outside....
thanks for you answers so far.
Old Jul 31, 2002 | 02:58 PM
SPROCKET's Avatar
SPROCKET
Wierd problem....
try bleeding your slave cylinder, sounds like you got air in the line.
Take Care,
Justin
Old Jul 31, 2002 | 03:05 PM
Mauser8mm's Avatar
Mauser8mm
Wierd problem....
Check you fule filters first then check you spark plugs for carbon or oil. And also check your air filter it might need to be replaced. Good luck!
Old Aug 1, 2002 | 04:04 AM
AKFord's Avatar
AKFord
Wierd problem....
lawdawg79
Dec 10, 2015 02:35 PM
JeffK
Jul 14, 2015 04:14 PM
gt350h
Jun 13, 2010 01:32 AM
stunod2002
Nov 30, 2004 01:54 PM
bassdude
Sep 15, 2003 04:17 PM
