92 A4OD overdrive question
Old Nov 9, 2007 | 07:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yerds. Leave it in overdrive. If you get frequent shifts out of overdrive, press the button that turns off the overdrive.
Old Nov 26, 2007 | 08:19 PM
gymcoal's Avatar
gymcoal
This tread help me figure out my MLPS installation issue on my 93 E350 Motorhome. My problem was that when I put the new MLPS (to solve my neutraling issue) the selector shaft also came out a 1/4 of an inch like Darylz, but the valve inside the trans slid forward and was then the trans was stuck in first. After dropping the trans pan and reconnecting selector shaft to the valve, I noticed that there is a small opening on flange where there is supposed to be a pin that holds the selector shaft in place so it cant slide out. I then cut a 1 inch piece of coat hanger and put it in the hole to hold the shaft from sliding out and disconnecting the trans valve from it. The pan & gasket then hold it in place. If any of you have dropped your pan recently and found a small pin that they could not locate where it goes... don't pull on your selector shaft or you may stuck in gear. Anyway, I thought I would just share my experience. Thanks!
BDFD
20
Jul 23, 2024 12:06 AM
Transam461
Sep 10, 2016 12:58 PM
ridemech
Apr 16, 2016 11:19 AM
lievense81
Aug 26, 2015 06:38 PM
HMS
Mar 2, 2014 02:41 AM
