cheap build
Old Nov 7, 2007 | 12:27 PM
Strokin97's Avatar
Strokin97
cheap build
anyone no where i can get a *17 hpop and other parts to do a cheap build up on a 97 7.3 to get a decent amount of power out of already have turbo and innercoler
Old Nov 7, 2007 | 02:36 PM
StrokeThis96's Avatar
StrokeThis96
i've heard of people gettin the 17hpop from junkyards on a SD. im sure junkyards would be a good place
Old Nov 7, 2007 | 02:37 PM
StrokeThis96
i've heard of people gettin the *17 hpop from junkyards off of a SD. im sure junkyards would be a good place to look
Old Nov 7, 2007 | 03:11 PM
tjbeggs's Avatar
tjbeggs
Hpop
http://www.mwfi.com/_template/templa...%20Oil%20Pumps
Also if you have connections at an IH dealer you can get a HPOP for around $350 as well.
Get a chip here
http://stores.totaldieselperformance.com/StoreFront.bok
http://www.dp-tuner.com/73tuning.htm
Injectors here
http://www.diy-injectors.com/
http://www.beansdieselperformance.com/
But unless you already have intake, exhuast and gauges...those need to be first on your list. Then if you do go with larger injectors you need some tranny mods to hold the power. Also no matter what you do now a larger tranny cooler should be looked into.
Old Nov 7, 2007 | 03:30 PM
MADVAN's Avatar
MADVAN
Cheap!
If you find a way, let us all know!
Bill
Old Nov 7, 2007 | 03:57 PM
tjbeggs's Avatar
tjbeggs
yep modding these truck is only cheap when compared to buying a brand new one!!
Old Nov 7, 2007 | 08:06 PM
Strokin97's Avatar
Strokin97
i have an H2E ,gauges, exhaust, intake, innercooler and pullin the auto out and swaping in a manual
Old Nov 7, 2007 | 09:16 PM
tjbeggs's Avatar
tjbeggs
First I think you should read this thread regarding your tranny choice. Just my opinion but its an option
https://www.ford-trucks.com/forums/6...o-5-speed.html
Also you have a great start to a performance truck. I would suggest a DIY stage 2's kit for injectors and a chip from total diesel performance (tony wildman) burned for the injectors.
On a side note how do you like the H2E? Is it laggy with the stock injectors?
Old Nov 8, 2007 | 09:02 AM
Strokin97's Avatar
Strokin97
only 5 of the injectors work right and even with the junk edge chip it totaly killed my tranny but im also runnin 36 15.50 tires
