Sponsored by: Real Truck
Engine Braking
Old Nov 7, 2007 | 11:34 AM
Wayno's Avatar
Wayno
Engine Braking
Hello All,
My first Ford HD, so you guys are a Godsend. Bought 2001 F250 used so unclear on history. Bought at 110K, Trans scattered at 121K. "completely" rebuilt. Shifts fine but no engine braking. Trans shop said all OK as far as the trans goes. Maybe the chip. Took to Ford, there was a super chip of some kind, but as no controller came with truck, I had Ford restore to spec. Still no engine braking. The Ford tech mentioned a "one way clutch" which I'm guessing is a " coast clutch. I believe that when I manually drop a gear, the tach should show higher RPM and track slowly down as the truck loses speed. I gotta take it back to the Trannie shop, and it sounds like their going to have to tear it down again. Any comments, insights, advice VERY welcome!
2001 F250 Crew 4WD with 7.3 Diesel
Old Nov 7, 2007 | 11:48 AM
rbaker6336's Avatar
rbaker6336
you should have a coast clutch think it comes on from 40mph up,mine takes a rew seconds to come on and will stay on unless I touch the brake then will release
Old Nov 7, 2007 | 12:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, that's not how the coast clutch works.
It's NEVER on in 4th gear, because there is always engine braking in 4th. It's very slight due to the trans ratio in 4th, so it isn't really usefull.
The coast clutch will come on in 3rd gear ONLY if the OD off light is on. If the OD light is off the coast clutch stays off in 3rd.
The coast clutch will come on in 2nd gear ONLY if the OD off light is on, or the shifter is in the 2 position. If the OD light is off and the shifter is in D the coast clutch stays off in 2nd.
The coast clutch will come on in 1st gear ONLY if the OD off light is on, or the shifter is in 1. If the OD light is off and the shifter is in D the coast clutch stays off in 1st.
Around 2001 there was a machining problem with the coast clutch drum. The groove for the snap ring that holds the clutch together wasn't machined deep enough and the snap ring would often come out of the groove. When that happens the coast clutch no longer works. Usually, but not every time, it won't break other parts, but sometimes it does.
Old Nov 7, 2007 | 01:10 PM
rbaker6336's Avatar
rbaker6336
I beg to differ mine for sure works in fourth gear
Old Nov 7, 2007 | 02:00 PM
Mark Kovalsky
If your coast clutch is on in 4th gear the trans will be locked up. All three elements of the overdrive gearset will be held to the case, so the input and output shafts will stop turning. That means the wheels are going to stop turning, too. Your coast clutch IS NOT on in 4th gear. It can't happen.
You will have engine braking in 4th gear because the overdrive clutch is on and provides engine braking in 4th gear instead of the coast clutch, which CANNOT be on in 4th.
I think you are mistaking the torque converter clutch for the coast clutch.
Old Nov 7, 2007 | 02:55 PM
Wayno's Avatar
Wayno
So what I think I'm hearing is that the coast clutch, when activated by the OD (OD light is ON) allows the truck to coast without engine braking.
I assume engine braking, in 1st, 2nd or 3rd, will cause my engine to wind up, and through compression, slow or hold my truck to a lower speed so I don't have to burn up my brakes. Every vehicle I have (Explorer, Toyota 4Runner and even car) has this capability.
So when Ford says the problem is likely in the trans, would it be the Coast clutch always on, or the TC clutch. There was a short in the shift stem, (blew fuses when put in OD), and the shift stem was replaced by the guy that rebuilt the trans. Maybe the Coast Clutch is always engaged without the OD lamp lit????
Old Nov 7, 2007 | 03:32 PM
rbaker6336's Avatar
rbaker6336
all I know if I am much over 40 mph no matter 45 or 100 when I let completely off the throttle it's like it down shifts to a lower gear and the rpms come up a little
if I touchthe brake it goes to a normal coast,when I let off brake it does the same again
if I lock it in third there is never sny change with throttle on or off
Old Nov 7, 2007 | 04:44 PM
Wayno's Avatar
Wayno
Thanks Guys. I think It's sinking in. I'm a newby to Diesels!! Borrowed my brothers '97 F250 for my frequent trips to AZ and was hooked. Nothing like hauling a truck load of material, and a trailer with the same, up the Kingman Grade like it was going down hill!
So from Ray's input here, looks like if I lock in third, the RPMs should track up and down. What I mean is the RPMs come up as I apply throttle (obvious) but should track down slowly as I let off the throttle (almost like I had a manual trans). As it is, I can be doing 40MPH in third, and when I let off the throttle it falls immediatly back to 1,500 RPM, and coasts to a stop. That ain't right. Worked OK till it blew.
I gotta go back to the trans shop, and need to be crystal clear so I don't get BSd again!
Old Nov 7, 2007 | 05:15 PM
Mark Kovalsky
No, that's backwards. When the coast clutch is on it provides engine braking. It is never on in 4th gear, but due to other reasons there is always engine braking in 4th gear.
EVERY vehicle has this capability. It's a Federal Motor Vehicle Safety Standard (FMVSS.) Your's doesn't because something is not working right. It's probably the coast clutch snap ring.
The problem is that the coast clutch is never on. It isn't working. It's probably the snap ring like I said earlier. The torque converter clutch can be on or off and there will still be engine braking, as long as the coast clutch will come on when it is supposed to.
That's not related.
To test the coast clutch, drive at 40 MPH and take your foot off the go pedal. Move the shifter to 2. If there is engine braking the coast clutch is working. If the engine drops to idle speed then the coast clutch is not working.
Old Nov 7, 2007 | 05:18 PM
Mark Kovalsky
That shows that your torque converter clutch stays locked at closed throttle. Some Ford calbrations did that, and some didn't. Both have engine braking, the ones that have the torque converter clutch locked at closed throttle have about 10% more engine braking.
Since your's works with the OD off, your coast clutch is working as it should. Wayno's truck won't do this. His is going to idle speed, which means the coast clutch isn't working. It doesn't tell anything about the torque converter clutch, which is a different clutch.
Old Nov 7, 2007 | 07:36 PM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
dose the programmer have that as an option
dose it have an after market converter in it? if so they may need anouther liner on the overdrive disk
if you have any questions, call 888-267-7464
Old Nov 8, 2007 | 12:22 AM
Wayno's Avatar
Wayno
Thanks to all!
It sank in!
I got quite an education from all of the responses.
Old Nov 8, 2007 | 08:07 AM
aldridgec's Avatar
aldridgec
I agree with everything Mark said. Nothing to really add either.
Old Nov 8, 2007 | 09:44 AM
edjunior's Avatar
edjunior
I couldn't dispute or add to what Mark said, but wow, that is a wealth of knowledge there! His sig says it all..."Former Ford automatic transmission engineer, 1988-2007." And I have no reason to doubt it. Thanks Mark!
Old Apr 22, 2008 | 08:07 PM
Wayno's Avatar
Wayno
Tranny fixed!!! Mark Kovalsky nailed it Replace coast clutch drum (2001 shallow machined groove for snap ring) and now performs great. Drove heck out of it and all is well. I printed up some of the insights provided by members of this forum, and presented to rebuilder along with diagnostics from Ford and after the 3rd teardown, all is well. The rebuilder even restarted my 1 year / 12K warranty! Thanks again!!!!
