fuel gauge stuck
Old Nov 7, 2007 | 12:13 AM
kupaa's Avatar
kupaa
fuel gauge stuck
just filled up my tank in my truck and my fuel gauge dident move and when it finally did it only went up to half tank and it took about 20 min.any ideas why?could it be electrical cause my fuel is clean?changed my fuel filter at 10000 miles and was dark gray or light black but still could see the white in the filter.Thanks
Old Nov 7, 2007 | 12:45 AM
ernesteugene's Avatar
ernesteugene
Mine has done the same thing, but it has only happened about 6 times in the past 3 years. First time it happened I'd fueled at truck stop and had a very high flow rate going into the tank, and I thought that might've jimmied up the sending unit. It gradually moves up to full within 5 miles or so, so I don't worry about it, but I do double check fuel level with the trip odometer.
Old Nov 7, 2007 | 07:44 AM
Kwikkordead's Avatar
Kwikkordead
Did you turn your engine off when refueling?
Old Nov 7, 2007 | 08:13 AM
WMRiceman's Avatar
WMRiceman
I concur with kwik, if you leave the truck running while refueling, it takes a little time for the computer to average everything back out. One cycle of the key and it should read full. This is not a problem, just a feature of our trucks you might say. If you cycle the key and it doesn't read full, you might have a problem.
Old Nov 7, 2007 | 09:27 AM
kupaa's Avatar
kupaa
Smile
The engine was off.drove to work and only showed half drove back home and went to 3/4.anyways its a good reason to do my in tank mods.thanks
Old Nov 7, 2007 | 05:03 PM
ernesteugene
I've never shut off my engine when refueling.
Old Nov 8, 2007 | 12:20 AM
stang8893's Avatar
stang8893
I've had it happen in my 99. For that tank of fuel I just use the trip odometer and when I fill it up again it was fine. Hasn't happened again
Old Nov 8, 2007 | 01:41 AM
kupaa's Avatar
kupaa
thanks everyone,i hope it doesent happen again.
Old Nov 8, 2007 | 08:52 AM
powderspecial600_98's Avatar
powderspecial600_98
I have the opposite problem, my fuel guage stays on full all the time. Every once in awhile it will work correctly, but the next time I look at it's back on full.
Old Nov 8, 2007 | 10:02 PM
kupaa's Avatar
kupaa
could it be an alge problem?
Old Nov 8, 2007 | 11:19 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Mine has done it a couple of times in the last few years.....
tractoman
May 8, 2014 01:22 PM
05F250DSL
Nov 15, 2013 07:04 PM
mickpowell1967
Aug 12, 2009 10:33 PM
oldbird1965
Aug 4, 2009 05:20 PM
lazyscholar
Apr 12, 2008 01:08 PM
