Ball Joint Replacement
Old Nov 6, 2007 | 10:41 PM
THUNDERHEAD95's Avatar
THUNDERHEAD95
Hi Guys, I have a '95 F-150 4x4 w/ the 302. It needs new ball joints and I don't have the $800 that a mechanic quoted me to change all 4 ball joints, both u-joints, and both hub locks, so I'm gonna have to do it myself. I was wondering if any of you guys can give me some advice or recommend any literature on the process. I rented a press tool but I'm not sure if there are any other tools, other than the obvious, that I may need to buy/rent. Any help you guys can give would be very much appreciated. THANKS JSP
Old Nov 7, 2007 | 05:42 AM
QA Guy's Avatar
QA Guy
Hub socket to take wheel bearings off. Big Hammer. 800.00 sounds steep.
Old Nov 7, 2007 | 06:47 AM
aj197816134's Avatar
aj197816134
Using moog parts for chassis, I priced this recently and I know the parts from a website were around 350.00 including tie rod ends. I know around here they charge 77.00 per side labor to do ball joints. Did this include an alignment. Only thing I recommend is using QUALITY parts, it doesnt pay to go cheap as you will have to do the job again in a year or so. Make sure you keep the new Ball Joints are greased.
machinist91
May 19, 2013 12:52 PM
xamack24
1983 - 2012 Ranger & B-Series
Oct 3, 2010 04:47 PM
MikeMcCasland
Nov 29, 2009 09:50 PM
vze2sgxa
Sep 17, 2008 05:28 AM
oldstylefseries
1997 - 2003 F150
Sep 26, 2006 09:38 AM
