Dim instrument lighting
Old Nov 6, 2007 | 10:37 PM
parr4's Avatar
parr4
'81 F100. All the bulbs for the instrument panel light ok, but are very dim. Reostat control works ok, so I'm stumped. Can not find any troubleshooter for this, so I'm hoping for some suggestions. Thanks
Old Nov 6, 2007 | 11:09 PM
82F100SWB's Avatar
82F100SWB
You will get suggestions to remove the bulb covers, and possibly a few other things, but, what has always has worked to me is to put in all fresh bulbs, and then clean all of the connections to the printed circuit, including the main cluster connector. I usually do this with all of the bulbs and guages, and everything works as it should.
That's what the dash should look like with the lights cranked all the way up.
Personally, I run them very nearly turned off, as having them cranked up takes away considerably from your night vision in conditions such as I drive in, where there are no street lights to be found for hundreds of miles...
Old Nov 7, 2007 | 02:21 AM
PsychoworkS's Avatar
PsychoworkS
I have the same problem with my truck and I was wondering what to do about it.
How do you recommend cleaning the contacts? I've heard that a pencil eraser works well.
Thanks for the post.
Old Nov 7, 2007 | 11:12 AM
parr4's Avatar
parr4
82F100swb....I appreciate your thoughts. Changing the bulbs doesn't make sense, because they illuminate now. Cleaning all contacts makes sense. I bought this truck new and electrical contacts have probably accumulated 'dirt/scum' over the 27yrs. I intend to check the rheostat voltage In/Out before I proceed with removing the panel. I also intend to check the Ground connection.
Your picture is what I know they should illuminate to....I remember when it used to.
Your speedometer goes much faster than mine! 120+!! Best mine can do is 85+.....
Old Nov 7, 2007 | 01:01 PM
PsychoworkS
Yeah, but his speedo reads Km/H.
Old Nov 7, 2007 | 02:19 PM
starmilt's Avatar
starmilt
If 120 is kilometers then what is the numbers where kilometers is on every other rig.
Old Nov 7, 2007 | 02:37 PM
PsychoworkS
Huh?
Would you mind explaining just what you mean?
Old Nov 7, 2007 | 02:46 PM
runitsdafuzz's Avatar
runitsdafuzz
the 80 right next the the 120 is mph it says mph right under the 80
Old Nov 7, 2007 | 03:50 PM
hoxiii's Avatar
hoxiii
it's KM/H on teh outside and MPH on the inside.
Pencil erasers work if the gunk isn't too thick. if it is, use some electrical contact cleaner and a pencil eraser.
Changing the bulbs does help sinc ethey do dim over their lifespan.
Check the rheostat, it can go up in resistance over the years.
Check the wiring from you alternator to the main harness. Cleaning all of this did the most for my dash lighting.
I also don't like taking teh green film off of the bulbs, the unfiltered light is just too harsh IMO.
Justin
Old Nov 7, 2007 | 07:56 PM
blue beast's Avatar
blue beast
Get the pen that increases conductivity and cleans contacts from radio shack, It is
a good cantact cleaner easy to apply and really works and it leaves a protective coating. You could go and put LEDs in there and have it as bright as can be just put
a resistor on to dim to what you want the brightest setting to be and go from there.
Radio shack also has a pen that lays down a coating of gold to keep the contacts
protected for along time!!
Old Nov 7, 2007 | 08:51 PM
WoomaHodal's Avatar
WoomaHodal
hmm those pens sound pretty good, i need to go investigate since my lights are pretty dim also
Old Nov 8, 2007 | 01:43 PM
parr4's Avatar
parr4
OH Yeah....km/h! Mine speedo is mph with the kmh undeneath. That truck was prolly from Canada. Thanks for the pen idea, although I don't much like dealing with RS.
Old Nov 8, 2007 | 02:32 PM
blue beast's Avatar
blue beast
Yeah me neither I don't buy anything from them but those pens. I go here and if you
are ever down in Florida doing the theme park thing head over to skycraft the mans
themepark!! Take a look at their pictures of inside the store!!
http://www.skycraftsurplus.com/index...S&Category=248
Old Nov 8, 2007 | 09:40 PM
Piffery1's Avatar
Piffery1
The white plastic part of the cluster gets yellow with age and loses reflectivity. You can pull it out and remove every thing and spray the inside with chrome or aluminum spray paint (Testors brand I think) for plastic models. You can remove the blue plastic bulb covers and replace the bulbs with colored replacement bulbs available at most auto parts. I.e. #194G for green.
johnmel59
Aug 4, 2013 04:24 PM
supercabfreak
13
Oct 20, 2010 01:38 PM
DBAPilotDad
17
Sep 1, 2008 01:08 AM
EDDY45
1997 - 2003 F150
Aug 27, 2006 11:52 AM
croessus
Aerostar
Mar 28, 2004 11:03 PM
