Cruise-control?
Old Nov 5, 2007 | 11:17 PM
tylstruck's Avatar
tylstruck
Cruise-control?
How complex would it be to add cruise-control to a truck that isn't equipped with it? What parts and mods should I be looking for?
Tyl
Old Nov 5, 2007 | 11:22 PM
Mil1ion's Avatar
Mil1ion
what year is it ?
If it is a 1979 then there is more info you need to know than what I listed here.
https://www.ford-trucks.com/forums/1...ng-cruise.html
Old Nov 5, 2007 | 11:32 PM
tylstruck's Avatar
tylstruck
The truck is a 1979 F350 one ton dually.
Tyl
Old Nov 5, 2007 | 11:38 PM
Mil1ion's Avatar
Mil1ion
what are the last 6 digits of the VIN ?
It makes a difference.
Old Nov 6, 2007 | 12:05 AM
tylstruck's Avatar
tylstruck
Canadian truck. The last six digits is; FD2933
Tyl
Old Nov 6, 2007 | 11:01 AM
Mil1ion's Avatar
Mil1ion
Okay Post DJ0001
That means you need the straight thru to pedal firewall booster.
Booster # 25*12831* - with push rod # FT-47
and Pedal stamped -SA
Old Nov 6, 2007 | 12:22 PM
tylstruck's Avatar
tylstruck
Truck does have power brakes via a booster. Is that adequate? You did mention FT-38 or FT-43 as brake booster, on the other post. Is that a part niumber stamped on the booster itself? If so, where would that be located on the booster?
I appreciate your help.
Tyl
Old Nov 6, 2007 | 04:20 PM
Mil1ion's Avatar
Mil1ion
It's on the end of the booster rod near the puch rod hole.
Okay next question.
does the booster push rod connect to the brake pedal with a bolt or a welded on nub like this ?
see the nub with keeper spring ?
I suspect a bolt.
Old Dec 3, 2007 | 04:23 PM
FBFord's Avatar
FBFord
I did it this way:
Originally Posted by tylstruck
How complex would it be to add cruise-control to a truck that isn't equipped with it? What parts and mods should I be looking for?Tyl
Tyl:
I added a Rostra cc module and switch (in picture below below gauge cluster/dash) to my '79 Ranger. Comes with good directions and goes right in. Didn't have to do any mods at all, actually, just linked per their rec's. Only small glitch, and it's probably a computer chip thing, is that every now and then when I tap it off with the brake I need to turn it off and back on instead of just "resume-" ing, but it's rare enough that it doesn't seem like an installation issue and isn't too terribly inconvenient.
Good Luck,
FBF
Old Dec 3, 2007 | 06:39 PM
ford390gashog's Avatar
ford390gashog
FBFORD,
Was the Rostra kit a full kit? I notice summit sells them but the description is vague.
