Esof
Old Nov 5, 2007 | 10:22 PM
bigtorque's Avatar
bigtorque
Esof
esof, major leak, the seals in the hubs are leaking says the shop, want 800 bucks to pull and replace both sides to include inner and outer seals,
that blows, guess im going manual for a while.
Old Nov 6, 2007 | 06:57 AM
JLDickmon's Avatar
JLDickmon
I went manual period
I put a set of Warns on my truck
seals leaked, replaced the seals.
vacuum lines leaked, replaced the vacuum lines
lines leaked again
seals leaked again
got Warns
Old Nov 6, 2007 | 07:55 AM
stroke-of-luck00's Avatar
stroke-of-luck00
WAIT!!!! the dealership told me the exact same thing! they were going to charge me $800 to fix the seal in my hubs. since i couldn't afford it anyways, i took it home, traced my lines (they were ok) and then figured out it was the vacuum solenoid. Went back to the dealership and picked up the part for $59 and put it in myself and now everything works perfect. i'd replace that first before you drop a bunch of money into your hubs.
Old Nov 6, 2007 | 10:09 AM
guzzle92's Avatar
guzzle92
Use a handheld vacuum pump on the vacuum port at the hub and see if it will hold. If it will not, then you have a seal problem. You can test each section of the vacuum system this way by simply isolating it from the rest of the system.
By doing some simple diagnostics, you can protect yourself from unscrupulous dealerships and mechanics.
On the other hand, if you really do have hub seal leakage and let it go, water and dirt will infiltrate your hub; take out the spindle bearing which will also ruin the 4x4 stub shaft. Metal flakes and rust will get into the main bearings and the entire hub unit will fail.
Old Nov 6, 2007 | 10:25 AM
bigtorque's Avatar
bigtorque
where is vacume solenoid?
Old Nov 6, 2007 | 12:07 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Mine ('o2 truck) is on the right fender (engine compartment) near the vacuum pump. Two bolts hold it on.
Old Nov 6, 2007 | 12:22 PM
bigtorque's Avatar
bigtorque
i will check it out, thanks
*-----but my heater goes straight to defrost when i turn on the auto hubs......
that means leaky leaky.
Old Nov 6, 2007 | 12:48 PM
stroke-of-luck00
big torque...mine defaulted to defrost too. still just the solenoid.
Old Nov 6, 2007 | 02:13 PM
bigtorque's Avatar
bigtorque
oooo, thanks i need to go home and check that.
