im looking to get a mid 90's ford f150, with a 4.9 and manual tranny. are there any particular years i should look out for;are 94's better than 95's...etc.
The only difference I am aware of is sometime around the mid 90s they changed between Mass Air Flow sensor vs Speed Density. I think Speed Density was earliler and handled mods better. The other didn't handle mods hardly at all. But I am really reaching in my memory. You should search this question if you plan to do mods.
Also seems I recall the cooling fan on the fuel rail was added around 92 maybe, so mid-90s you'd be okay on that.
I have a 94 300 and its speed density. My work truck is a 92 300 and its a speed density. The 94 with twice as many miles seems smoother than the 92. Neither one has the fan. We had an 89 EFI 300 and that had a cooling fan and did not seem as reliable as the newer models. Dual tanks seem to give a lot of problems. Some 96 models have MAF with the 300.
I have the manual and 3.55s stock tires. Love it
regards
rikard
87-94 EFI's are all OBD I SD/MFI. TMK most 87-92 had a thermal switched blower to 'cool' the injectors that was deleted in later models. Supposedly, the 95 EFI's for California (and some New York/Massachusetts) were OBD I MAF/SFI. All 96 EFI (the last year) are OBD II MAF/SFI.
Reliability/performance wise, there is little difference. If your looking for a workhorse try to find one with the ZF S5-42 vs the M5OD-R2, the ZF is a segnificantly stronger transmission with a good granny 1st and a slightly better OD 5th (.77 v .8). Mate that with a 3.55LS or better vs an open 3.08 differential and you have a truck that will done most anything, work wise, that you ask of it.
I would suggest not getting the EFI 300-6, plus you can always add carburators (I have* an 86' F-150 with a 300, three carb setup that runs like a raped ape XD)
while we are on the subject of mid 90's, all ive been finding are Eddie Bauer editions, are these still reliable work trucks or just big cars with a bed
I wonder why they removed the fuel rail fan. I thought it was more or less necessary. I noticed on mine the other day, looking up from below, that there is a big heat shield between the exhaust manifold and the intake manifold. Maybe that replaced the fan.
I have dual tanks and 147,000 miles and have not had any problems with them or the switching.
I'm further down the road than you and have dual tanks without problems. When I bought my truck the salesman told me to never run the tank dry before switching over. I listened intently to him. Thanked him for his advice, and always run the first tank dry before switching over. In fact, this is the third Ford with dual tanks, and I have never had a fuel problem on any of them.
I have a '96 4.9L it's MAF w/ Dual tanks and the M5OD trans - no problems with anything at 109K miles. (I've add the K&N air filter and TB spacer - I don't recommend - both did little or nothing for power or mileage)
Eddie Bauer is just a trim package. Same truck underneath. Some people have problems with the two-stage fuel pumps on the EFI trucks- low pressure in the tank, high pressure on the frame rail. Sometimes the tank selector valves go. All are replaceable.
Carb'ed trucks can run fine, but need lots of bolt-ons to equal the power of an EFI motor.
All are good trucks. I've had both- carb'ed and EFI, and they're all good trucks. 300 is a solid motor, in any incarnation.
