Trans Temp Gauge IN!
Old Nov 5, 2007 | 08:54 PM
  #31
flareside_thunder's Avatar
flareside_thunder
RoadVirus...the cluster looks good...I needatake somepics of mine...i got the 3 tier setup and the pod holders on mine are alittle rounder.....I just got done hooking up the OP gauge...not that tat helps a non running truck.....I think I got a volt meter and a fuel pressure...I'll ditch the fuel pressure for somethin else.....don't know what tho.....that SAT pod is distracting but the Trans gauge looks good...you're braver than I am drilling holes in your dash...Looks good Skan....
JR
Old Nov 5, 2007 | 09:50 PM
  #32
jk89cat's Avatar
jk89cat
i got a double pod and a column pad, i too am against drilling dashes, i am running a oil pressure, coolant and trans temp , i put the sender in the upper line. (e4od)
Old Nov 5, 2007 | 10:09 PM
  #33
Skandocious's Avatar
Skandocious
You guys are all sissies! If the gauge is permanent (and it is) then what is the problem?
Old Nov 6, 2007 | 05:37 AM
  #34
QA Guy's Avatar
QA Guy
If you keep your truck long enough, you will find out that the only thing that is permanent is change.
Old Nov 6, 2007 | 10:01 PM
  #35
jk89cat's Avatar
jk89cat
i couldnt agree more
Old Nov 6, 2007 | 11:02 PM
  #36
Mr. M's Avatar
Mr. M
Again... I must concur.
Chris this gentleman's point is without flaws. I've owned three Ford trucks dear to my heart, and this statement rings true for all of them.
I must state however... that all three are still running!
Mike
Old Nov 6, 2007 | 11:07 PM
  #37
Skandocious
What're you guys tryin' to do here? Make me feel stupid for mounting it to the dash? I gave careful thought to doing a pillar mount and decided I didn't want it. I don't regret mounting to the dash thank you very much.
Old Nov 7, 2007 | 12:17 AM
  #38
eco's Avatar
eco
Hmmmm, kind of an oxymoron. Never thought of this before.
Skandocious
68
Jan 19, 2008 01:06 PM
Skandocious
26
Jan 13, 2008 08:56 PM
Skandocious
76
Jan 13, 2008 08:20 PM
Skandocious
19
Sep 29, 2007 06:22 AM
Skandocious
43
Jun 26, 2007 11:11 AM
