Trans Temp Gauge IN!
Old Nov 5, 2007 | 12:13 PM
TheRoadVirus's Avatar
TheRoadVirus
I'll get a pic for you later on when I go take a vid to post up to see if anyone knows the noise that's going hand in hand with my fluctuating idle.
Old Nov 5, 2007 | 12:20 PM
Skandocious's Avatar
Skandocious
Originally Posted by eco
Bellhousing? Try that again with the cooler lines and see what you get...the inlet and outlet at the cooler and/or the trans to be specific. That and maybe the bottom of the trans oil pan just to see what it says there.
Bellhousing was my best option short of pulling the grommit to the TC and shooting that, but I got home at 2am and wanted to go to bed. I did shoot the pan and it read around 100* I believe... I'm pretty sure that the pan is getting cooled a good bit by the air passing under the cab. As for the cooler lines, well... I was gonna start a new thread but maybe I can get some answers here...
I haven't felt the cooler lines near the transmission but last night when I got home, I grabbed the cooler line right before it entered the cooler (in the engine compartment) between my thumb and forefinger and it was cool to the touch... As in, cooler than even the engine compartment seemed to be... With a transmission at 130+ degrees, shouldn't my cooler lines be AT LEAST warm? I'm thinking they might be clogged Whatchu guys think?
Old Nov 5, 2007 | 12:36 PM
eco's Avatar
eco
First find out which is pressure and which is return (I probably have that info). Then get readings at the tranny, then at the cooler after a good drive. The fluid leaving the tranny should be fairly warm needless to say and the fluid entering the tranny should be cooler, but not THAT much cooler. If there is a difference between the fluid leaving the tranny and the fluid ENTERING the COOLER, then obviously you have a blockage problem and you will just have to take readings all along the cooling system to find the blockage...a temp difference in the line will find that blockage. Does your AT go through the raidiator? If this ends up taking time, you may want to get the wheels off the ground, start the motor, put the e-brake on and put the trans in drive to keep the ATF at operating temp so that you can continue to get good readings.
Had you installed one sensor in the pressure line and another in the return line you would have found this right away, and you would find it right away if something like this were to happen again. The test port will not alert you of these problems.
Old Nov 5, 2007 | 12:39 PM
Skandocious
Good call, I'll do that next weekend. And yes, my cooler lines go through my radiator. Hey so which line is the outgoing and which is incoming at the e4od transmission? IIRC the lines are horizontally level and one is further forward than the other.
Old Nov 5, 2007 | 04:00 PM
lostin90s's Avatar
lostin90s
Good one chris I've been reading up on this and the oil presure swap to be a reader instead for idiot light type
Old Nov 5, 2007 | 04:06 PM
Skandocious
You're talking about swapping the connections on the stock oil pressure gauge so that it's more accurate?
Old Nov 5, 2007 | 04:24 PM
cleeE150's Avatar
cleeE150
Skandocious gauge setup looks great.....keep on truckin
Old Nov 5, 2007 | 04:29 PM
msb71's Avatar
msb71
I like the gauge setup there, another new toy for your cali truck .
Mike
Old Nov 5, 2007 | 04:36 PM
Skandocious
Thanks guys! I'm pretty happy with it so far, it turned out even nicer than I thought it would.
Old Nov 5, 2007 | 04:42 PM
TheRoadVirus
Keep in mind it isn't in it's final attached position.. but yea.
Old Nov 5, 2007 | 04:44 PM
Skandocious
Ahhh!! The glare is blinding!!
Is your interior plastic black to match the gauge pod?
Old Nov 5, 2007 | 04:49 PM
TheRoadVirus
Yes, indeedy. Gotta love the rusty vent window, too.. Uh baby.
Old Nov 5, 2007 | 04:50 PM
  #28
Skandocious
Mmmm sexy rust.
Old Nov 5, 2007 | 07:07 PM
  #29
EPNCSU2006's Avatar
EPNCSU2006
Originally Posted by Skandocious
Yep, electric sending unit. I've read that the mechanical MIGHT be more accurate by 3 or 4 degrees... But to deal with all that copper line and worrying around it getting punctures and making an ATF mess in my truck... Not worth it...
I would have gone electric too, but with temp gauges, the tube is sealed from the factory and is filled with ether, so none of the measured fluid would ever be able to get to the gauge unless there was a hole in the measuring bulb. Even then, it shouldn't leak into the cab. Pressure gauges is where you run the risk of fluid leaks at the gauge in the cab.
The placement looks pretty good on the gauge - easy to read at a glance. That satellite radio looks like it would be distracting, though
Old Nov 5, 2007 | 07:24 PM
  #30
Skandocious
Ahh that make sense I just read on some other forum and the guy mentioned ATF leaking around (and possibly in the cab...)
It was distracting when I first put it in (several months ago) but I've gotten used to it, not a problem anymore
