Sponsored by: Real Truck
steering stabilizer
Old Nov 4, 2007 | 07:51 PM
FTL40's Avatar
FTL40
steering stabilizer
2006 250 5.4 4x4. i have bilsteins and they halped a shaking a lot but i still have a bit. was curious if anyone knows of a stabilizer that works with stock suspension
Old Nov 5, 2007 | 12:40 AM
drbalazo's Avatar
drbalazo
maybe consider getting dual stabs. Donahoe Racing is a good brand.
Old Nov 5, 2007 | 07:31 AM
snelldawg's Avatar
snelldawg
If it's stock, then duals won't work. It has been talked about here several times, just do a search.
With the dual stabilizer system, on rough terrain the track bar contacts the center bracket driving it down into the tie rod causing binding in the steering.
So to replace the steering stabilizer on an 05-07 stock height SD you need to just replace the factory unit with a HD unit in the same location.
Old Nov 5, 2007 | 07:42 AM
one_wicked_element's Avatar
one_wicked_element
I bought a Monroe one for my 01 SD from Shockwarehouse.com
I also paid the $4 dollars for the boot for it.
The only problem I had was one end didn't fit because it had a bushing in it. I took the bushing out, and it fit fine.
I think the total was around $44'ish.
Mine wasn't bad at the time, so I didn't notice too much of an improvment. I just changed it out when I did my shocks.
Old Nov 5, 2007 | 08:44 AM
drbalazo's Avatar
drbalazo
oops, I answered your question thinking it is lifted. The duals work best when lifted.
Old Nov 5, 2007 | 09:05 AM
rmosso1's Avatar
rmosso1
I experienced the same thing. After putting on 4 billsteins I had the Monroe shock put on. Solved all the death wobble/vibration. My bet is that this is a maintenance item, and if I don't trade my truck I will change the front stabilizer every 20,000 miles. I had 30,000 miles when I put the new Monroe stabilzer on. I could play the old one like an accordian in my two hands. Obviously wore out. Change it and your problems will be solved. Mine is a 2005, F-350 6.0 PSD long bed.
Old Nov 6, 2007 | 12:21 AM
FTL40's Avatar
FTL40
alright sounds good. my truck does not even have 10k on it and 3 out of the 4 stock shocks were junk. the stabilizer is prob the same. the monroe is the only one who makes one for us?
Old Nov 6, 2007 | 06:20 AM
rmosso1's Avatar
rmosso1
I don't know, but shockwarehouse sent me the Monroe. They seem to know what they are doing. Also, from another source, I understand that the RANCHO's we have are pretty much knock offs from MONROE.
Old Nov 6, 2007 | 05:49 PM
FTL40's Avatar
FTL40
do all superdutys have a stabilizer? anyone have any part #s for the brackets because i dont think mine came with one
Old Nov 6, 2007 | 06:20 PM
BGMSPD's Avatar
BGMSPD
i put a procomp on mine and love it. took the stock one off at 14,000 or so and what a difference even running larger tires.
Old Nov 6, 2007 | 08:40 PM
FTL40's Avatar
FTL40
because i have an 05 i dont think procomp makes one for the standard suspension
Old Nov 7, 2007 | 06:33 AM
BGMSPD's Avatar
BGMSPD
check out their site. www.explorerprocomp.com/
they have one listed:
Ford Super Duty
05-07 F250/F350 4WD 227010 is the complete kit part#.
Old Nov 7, 2007 | 06:39 AM
rmosso1's Avatar
rmosso1
My understanding is that the answer is yes. A qualified yes, as all super dutys with coil springs, which I believe are trucks built starting in 2005. Someone can confirm, but with the change to coil front springs from leaf springs caused the need for a front stailize, imho.
Old Feb 12, 2008 | 10:23 PM
mtford's Avatar
mtford
I have a 00' f350 PSD with a 2" lift on frt. Does anyone know how much lift is needed to install a dual steering stabilizer set up?
Old Feb 13, 2008 | 01:32 AM
mstiles19's Avatar
mstiles19
no my 2001 didnt have one i think i put a rough country on it i ordered it with the bracket and it was easy to put on it was just a few bolts
