transmission cable broke
Old Nov 4, 2007 | 05:09 PM
mack6820's Avatar
mack6820
Hey guys. I finally got the whole dash back together after changing out my heater core. 98 Expy. Now my truck wont start. Everything works, but when I turn the key, all lights go out and nothing happens. I looked under the steering column and found my transmission shift cable broken. Do ya'll think this could be why it wont start?
Old Nov 4, 2007 | 06:00 PM
FTE Herman's Avatar
FTE Herman
What happens when you just turn the key to the 'on' position?
Old Nov 4, 2007 | 06:42 PM
mack6820's Avatar
mack6820
all the lights come on as usual, but when I turn it to start, everything goes dead. Kinda light a dead battery but I know the battery is good.
Old Nov 5, 2007 | 01:23 PM
TexFinn's Avatar
TexFinn
It could very well be due to the shifter cable. It might have moved the shifter lever at the tranny's end to something other than P or N and hence won't crank.
Replacing the shifter cable is very easy. I did that on my old 00 EB a couple of years back. I think the cable cost me less than 100 bucks and the installation took less than an hour. Very straightforward job.
Old Nov 5, 2007 | 07:40 PM
FTE Herman's Avatar
FTE Herman
^I concur.
Old Jun 7, 2010 | 03:09 PM
pablocruz69's Avatar
pablocruz69
I had the same issue, I got the cable back on but now there is a lot of play in the shifter, I have to wiggle the shifter to get it to go in to drive, reverse. I tried using a cable tie to take up some of the slack but that didn't help. Someone said that there was a very specific way to install the cable but I haven't been able to find anything on here as to what the steps are to install the cable. Thanks
Old Jun 7, 2010 | 08:35 PM
alloro's Avatar
alloro
Your adjustment is off down on the tranny.
Kristof
Jul 20, 2013 12:39 AM
Old_Crow
13
Jul 25, 2010 11:12 PM
62stepside
23
Dec 20, 2006 03:47 AM
plilikoi
Bronco II
Feb 28, 2006 07:44 PM
hustjona
Dec 26, 2005 06:45 PM
