Speedometer doesnt work
Old Nov 4, 2007 | 09:16 AM
Duceswild's Avatar
Duceswild
Lol well it hasnt been working for a while but im finally getting a chance to work on my ole girl... but im looking in my haynes manual and lucky me i cant find anything on how to fix it... im assuming the cable went bad or something but im not sure any help would be appreciated...especially since my gas gauge and second tank both dont work so if i run ot i run out lol...(i use to keep track of miles)
Old Nov 4, 2007 | 01:14 PM
mrl390's Avatar
mrl390
What truck do you have? Year, model, transmisson? No one can help you until you give us more info.
Old Nov 4, 2007 | 01:24 PM
Skandocious's Avatar
Skandocious
Yeah we need more info about your truck.
If you've got a digital odometer, does that still have a reading on it or is it blank?
Old Nov 4, 2007 | 01:29 PM
Duceswild's Avatar
Duceswild
im sorry i forgot to add that guys.. its
1989 ford f150 5.0L Xlt
regular gauge with a needle and all... and it doesnt move at all neither does the odometer
Old Nov 4, 2007 | 01:30 PM
mrl390's Avatar
mrl390
Thats what I was wondering. I know the older trucks 87-91 have a cable controlled speedo. The problems with the older ones could be a bad speedo gear or a bad cable. The newer ones 92-96 have the electronic controlled speedo and with that your problem could be as simple as a bad fuse which would cause the speedo and the odometer to not work.
Old Nov 4, 2007 | 01:31 PM
Duceswild's Avatar
Duceswild
im hoping its a bad cable since i already bought it and will be picking it up tommorrow but whwat do ya'll think
Old Nov 4, 2007 | 01:32 PM
mrl390's Avatar
mrl390
Beat my post. Ok since you have the older, cable controlled speedo/odo I would start at the guages. Check to make sure the speedo cable is still attached at the back of the guages. Follow the cable all the way to where it meets the transmission and make sure it isnt loose there. Then the worst cause (and most likely) would be a bad speedo gear in the tailshaft.
Old Nov 4, 2007 | 01:52 PM
Bear1_301's Avatar
Bear1_301
You could take the cable loose from the tranny & put a drill motor to it & see if the speedo works? If it does work with that, then I'd say it was the gear in the tailshaft, they aren't hard to change. AS far as the gas gauge check fuses & make sure gas tank has a good ground.
Old Nov 4, 2007 | 02:22 PM
Duceswild's Avatar
Duceswild
hmm im gonna try that and find it from the tranny first to check for the gear for the reason i sorta did something i shouldnt have... well long story short the **** for the light and the wipers broke and i managed to find some real nice ones in my garage that fit but wouldnt stay by itself so i umm well glued them....and if taking off the pane is like it was on my other truck i would have to take off that panel... but i'll check either later today or maybe tommorrow
Old Nov 5, 2007 | 12:40 PM
Duceswild's Avatar
Duceswild
any idea how i can take of the panel without having to take off those *****?
Old Nov 6, 2007 | 03:45 PM
Duceswild's Avatar
Duceswild
alright guys i got it working.... ended up being the pinion gear which was really really reallly easy to replace...just took me 10 mins to change it...if anything the hard part was getting it :-p took me about 3 hrs since i went to one dealer that sent me to another and the second dealer sent me back to the first since apparently it was there all along ..... oh well working now thanks for alll the help
Old Nov 6, 2007 | 04:51 PM
Skandocious
Glad you got it worked out. Good work
Old Nov 7, 2007 | 12:14 PM
Duceswild's Avatar
Duceswild
lol thanks dude now only to get the fuel gauge working since its the last one that doesnt work :-p
