distributor on 352
Old Nov 4, 2007 | 07:42 AM
drof46's Avatar
drof46
distributor on 352
I have a 352 I want to tinker with and see if it will start. The dizzy is gone but I do have a 390 that still has one. Will it go in fine. The 352 is from 65 and the 390 is suppose to be from 72.
thanks
Old Nov 4, 2007 | 09:13 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Is the dizzy you have points or electronic? If points it's plug and play. I'm not sure what's involved for the elec tho. Someone will hopefully chime in on that. Parts store rebuilds are pretty inexpensive.
Old Nov 4, 2007 | 11:06 PM
f2501967's Avatar
f2501967
the 72 will have points also, ford didnt start using electronic until about 1974 or 1976, i forget which, cuz i was gonna switch mine to electronic but it was a money issue for me.
and 352-482 distrubutors are interchangeable.
Old Nov 5, 2007 | 12:48 AM
Bear 45/70's Avatar
Bear 45/70
Actually it's 332 thru 428. I wasn't aware of any 482s in the FE series.
Old Nov 5, 2007 | 03:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford went to electronic ignition in 1974 on cars, F100/350's, Bronco's and Econolines.
Dizzy's have ID numbers on them that can be traced to a specific year, engine size and the vehicle it was used on. On the curved side of the dizzy body will be a stamped Ford ID number like: D2TF-12127-PA. I can decode every Ford dizzy ID number from 1948 thru 1991.
Old Nov 5, 2007 | 05:20 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
482? 4.250 bore and 4.250 stroke. 482 FE.
dwestcessna
Dec 8, 2020 01:37 PM
wildwindjerry
Apr 24, 2015 09:56 AM
jazzy66
Sep 21, 2004 09:48 AM
ceetwarrior
Apr 19, 2004 03:18 PM
disvnvet
Apr 3, 2004 11:13 PM
