Computer Chips & Tuners
Edge Evolution with DP Tunes
Old Nov 3, 2007 | 09:08 PM
aocabrown's Avatar
aocabrown
Got a question for the DP folks. Looks like you can get an Edge Evo II with DP tunes on it....but only 3 tunes. One of the options is 'stock' Doesn't the programmer itself save 'stock' for you already so you should be able to get 3 real tunes on it plus the stock?
Also...the Edge with 3 DP tunes is a 'programmer' that would require shutdown before changing tunes....right?
The DP F5 switch with Chip is a set-on-the-fly deal right?
THANKS!
Old Nov 4, 2007 | 05:41 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Originally Posted by aocabrown
Got a question for the DP folks. Looks like you can get an Edge Evo II with DP tunes on it....but only 3 tunes. One of the options is 'stock' Doesn't the programmer itself save 'stock' for you already so you should be able to get 3 real tunes on it plus the stock? Yes. Unless you get the gameboy style (with out monitor) then you will get 5 tunes.
Also...the Edge with 3 DP tunes is a 'programmer' that would require shutdown before changing tunes....right? Yes the Evo is a downloader, so shut down is required between loading tunes.
The DP F5 switch with Chip is a set-on-the-fly deal right? Yes it is. It fits all EEC V applications. diesel and gas.
THANKS!
You're welcome!
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
DIYMechanic
58
Nov 23, 2013 11:28 AM
srfntheweb
Dec 22, 2012 09:16 PM
rwdfan
Jul 1, 2011 12:30 PM
Skinsfan6
30
Apr 1, 2011 01:45 PM
ForemanES
Apr 20, 2006 03:34 PM
