Rear suspension
Old Nov 3, 2007 | 07:59 PM
fords/harleys's Avatar
fords/harleys
Rear suspension
I want to put new pins and bushings in the rear shackles of my '55. Is there any tricks I need to know and how difficult is it?
Old Nov 3, 2007 | 09:58 PM
Randy Jack's Avatar
Randy Jack
There is a trick on removing the pins so you can drop the springs. Use an air hammer and punch through the hole in the frame. Are the springs off the truck yet?
Once the springs are off, the easiest way to drive out the bushings is the put a socket that is just smaller than the bushing OD on one side and a socket whose ID is bigger on the other. Then put a bolt through with a nut and screw the bushing out. OR, use a hydraulic press, if you (or a friend) have one.
Old Nov 3, 2007 | 10:51 PM
fords/harleys
No, the springs are still on the truck. I am going to tackle this job on monday(i have the day off). Thanks for the info. I knew somebody on this site would know.
Old Nov 5, 2007 | 08:53 PM
fords/harleys
Thanks for the help Randy Jack. Your ideas worked like a charm. The frame goes in for powder coating next week.
streaksf
2004 - 2008 F150
Nov 29, 2012 03:34 PM
dillinewton
Offroad & 4x4
49
Mar 1, 2010 09:52 AM
Maddog521
Escape & Escape Hybrid
Aug 25, 2008 09:23 AM
