Romp, Romp all gone
#31
#33
on
Originally Posted by just another truck
I wonder what/why the differences? I have ran synthetic since 1000 miles on my truck, and I have always had that romp first thing.....
I agree with "Just Another Truck" above.. I also think 15-40 is not right for our engines, especially in the colder climates..
#34
There seems to be too much confusion about what romp is. For me, it is the engine barely fires, about dies, barely fires again, about dies. It may romp once or twice or more and in really cold situations it rocks the whole truck. This is very different from a fluctuating idle, and goes away fairly quick but is very annoying and loud.
#35
on
#36
Since the fuel pump is running the whole time the WTS light is on, I'm thinking your HPOP is taking it's sweet time to build pressure.
#37
#38
I would say it is definately worth a try switching to synthetic. Mine did romp with Rotella but does it more now with the Delo??? I need to make a point of logging my ICP and IPR when cold starting but I am usually going hunting and do not have time. I know the reservior is full so my next step is a datalog and maybe a switch to synthetic. My problem is that it simply is not cold enough here right now for that kind of romping with the 15-40.
#40
Originally Posted by Kwikkordead
That sounds to me like something is not building pressure fast enough; HPOP oil pressure or fuel pressure.
#41
#42
Originally Posted by clintbonnie
Just curious.. what brand of syn oil and what weight have you been using.. I used Delo 400 since the truck was new and it always had the romp romp at start up.. but last year i switched to Shell Rotella syn 5w40 and it has never romp since.. (romping meaning the engine is changing rpm quickly from to almost normal rpm to almost dieing..this repeating back and forth..until the oil warms up abit and the injectors start working normally).
Tenn, when you gave your description, it sound identical to what I am saying, but i havent noticed anyone else mention this, I am in gear when this happens, I am at idile, but it in gear. It is normally three Romps and off i go.
#43
I have the same romp, even in the summer. If I leave the block heater plugged in, no problems. I occasionally get the SES light flashing (on for 1/4 of a second kind of thing) and then back off. When I check the codes, it is the ICP too high/low. I am going to try the orings on the IPR, and then will try starting it without the block heater. I will keep everyone posted.
#44
mongo75
01-02-2010 01:10 PM
natewoz
10-19-2008 07:52 AM
