Swaybar bushings.
Swaybar bushings.
So I'm trying to buy a swaybar bushing set, and I've hit a snag. Summit sells two kits a 33mm and 30mm kit. Both say F250 SuperDuty in the descriptor. I measured the sway bar between the two braces is 32mm. So who knows which one I should order.
I doubt the size would be any different, but I've got a gasser. The only reason I'm asking in here is I was having no luck in the SuperDuty forum. You guys seem to be a bit more acustomed to wrenching.
Thanks, Ethan
Thanks, Ethan
nb97f150
09-03-2003 06:37 AM
