I have a 64-65 F350 dump truck with a four speed and a 352 motor. I am doing a mechanical restoration before the body restoration to work all the bugs out of the truck and I was hoping someone could help with some torque specs.
Carburetor to intake
Exhaust manifold to head
Exhaust flange to manifolds
Drive shaft to tranny parking drum
Drive shaft U-Joint saddle at rear end
All bolts on the back of the spindle that holds brake backing plate
Axel to the leaf springs
Spindle nut for the wheel bearings
There should be a sticky on each forum for the torque specs for each class of Ford trucks discussed here. I surfed onto this page while looking for specs for my 95 f150.
