4.6 running rough when cold?
Old Nov 3, 2007 | 07:34 AM
87wreckerman's Avatar
87wreckerman
this question pertains to a 94 lincoln towncar with a 4.6, ive tried getting help from lincoln sites and other places on the web with no luck so figured id try on this site since its a ford engine, the car runs perfect once warmed up but the issue is when cold,when i go to start it in the mornings i have to hold my foot on the gas to keep it runnin,id say about 1500 rpm's, and during the time im helping it idle you can feel the motor running bad like its running off 5-or 6 cyl,real bad miss, and it also makes popping noises in the intake, once it gets completely warmed up it runs fine, occasionally it will idle funky once warmed but not alot,mainly only when cold, i get the CEL on every once in a while not much and not for long,maybe 10-15mins then it goes out,its OBD1 so i had a shop check it to see if there were codes still stored and not so...,once running i have no issues,car runs great and has lots of power, ive replaced the following in the past few weeks hoping to clear the problem- IAC, MAF , plugs & wires, engine coolant temp sensor , fuel filter, cleaned the TB, PVC, also did sea foam, after all this it still does the same thing when cold, now in the past few days i noticed a noise coming from my exhaust, like a rattling in the pipes up close to the cats or even manifolds, not sure if its related to the cold start issue but it is something new im noticing now, were do i look next?? cat conv poss plugged,how would i know besides replacing, no rotten egg smell? would the EGR produce this type of sign if it were bad or dirty, i herd you usually just get a CEL from bad egr no running issues usually?? pulling my hair out tryin to figure this out,any help would be greatly appreciated!!
CNYE350
Jul 11, 2013 01:37 PM
SeminoleSlim
25
Jul 15, 2008 10:32 PM
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
SeminoleSlim
Dec 26, 2007 08:40 PM
mhs53
Oct 9, 2007 06:00 PM
