Extracting Broken Compression Test Adapter
Old Jun 4, 2010 | 05:21 AM
  #31
rhkcommander959's Avatar
rhkcommander959
Yeah without the valve the gauge will just dance all day. I might just get that tester linked to on the first page. It wouldn't be too hard to adapt a valve for the harber garbage but if you can take it back the other isn't much more in price online.
I think harbor might have added a valve to the gauge too but I haven't been there to check
Old Jul 2, 2012 | 05:00 PM
  #32
Skip1970's Avatar
Skip1970
Originally Posted by tonian
Well, i did it and that is the only valve in the line so it didn't work. with limited access to fittings, i managed to adapt one of the other adapters in-line, #6 in the kit (according to the manual: http://manuals.harborfreight.com/man...3999/93644.pdf) with another $10 worth of brass fittings from the hardware store.
an easier way would be if you could find another one of the mini quick couplers (dunno if HF carries these, i couldn't get back to the store and they don't list them online), then you could use just a single 1/8" pipe coupler by snapping the extra QC onto the #17, putting the 1/8" pipe couipler on that, screwing the #10 adapter (w/valve) into that and then you could snap the guage hose onto that.
if you have a turbo though, you won't be able to stuff all that under it at #7 cylinder. i prolly have to go back and replace one of the straight fittings with an elbow.
my compression checked out ok but guess which cylinder had the GP with the burnt off end? grrrr.....
good luck with yours. if you come up with any better or shorter solutions, lemme know. i still worry about that #7 cylinder.
can you explain making the adapter i got the cheap 19.99 harbor freight kit and am trying to read th e6.9idi compression, do you just use the rubber ended push in thing?
Old Jul 2, 2012 | 05:58 PM
  #33
mistakenID's Avatar
mistakenID
Old post on an older thread. The guy has not been on in over a year.
AlexHunt
29
Feb 28, 2008 05:53 PM
65fordguy
21
Feb 1, 2008 10:22 PM
Big_Man_Brad
Sep 2, 2007 09:16 PM
tchad07
Oil & Lubrication
15
Jul 30, 2007 10:30 AM
tchad07
1978 - 1996 Big Bronco
May 9, 2007 09:36 PM
