Gear ratio.
Old Nov 2, 2007 | 01:41 AM
Bro107's Avatar
Bro107
Gear ratio.
Can anyone tell me what gear I have? This is what my tag says:WDM-C OA28
75 9 S314B
Thanks
80 F150
Old Nov 2, 2007 | 01:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
WDM-C = Ford 9 Inch Rear Axle / 2.75-1 / Non Limited Slip
Old Nov 2, 2007 | 04:10 AM
HemiEater's Avatar
HemiEater
looks like theres a 2. missing just before the 75....it's real close to the hole for the bolt...or it could be a 3.
Old Nov 2, 2007 | 05:12 AM
NumberDummy
I forgot to add the rear axle parts list number for WDM-C: 88.
Old Nov 6, 2007 | 02:17 PM
Bro107's Avatar
Bro107
Thanks for the info Bill. Kinda figured I had a low gear ratio,the truck came with P215-75R15 tires now I have LT235-75R15 on it. I'm thinking of going 3.08 . Maybe I should kick it up a notch or so and go 3.42 or 3.73.
Frank
80 F150
Old Nov 6, 2007 | 02:19 PM
HemiEater's Avatar
HemiEater
How are coming up with 2.75? from WDM-C??
Old Nov 6, 2007 | 09:41 PM
NumberDummy
Yes.
WDM-C is listed in the 1980/89 Ford Light Truck Parts Catalog under the Rear Axle and Differential Carrier ID Chart ~ Section 40, page 18. Once the code is found, the rear axle parts list number is shown. There are lots of parts lists!
The chart lists all the axle codes used during the 1980's on F Series, Bronco's, Econolines, Rangers, Bronco II's and Aerostars. Besides the W codes, there are the V & S codes (samples: V190-B, S307-B), Dana 7 digit codes (sample: 603943-3) and the Ford codes like: E1TA-AA, E7UA-AA, etc.
There's another chart just like this one in Section 30 for 4WD front axle codes.
All the Ford truck parts catalogs from 1957/ have these ID charts.
The 1980/89 catalog I'm using is the exact same one the dealers use.
Old Nov 7, 2007 | 03:48 AM
HemiEater's Avatar
HemiEater
so where did you get the ratio of 2.75?
kid1994
13
Jun 1, 2012 10:26 PM
95350PS
May 18, 2012 05:57 PM
blowhole
May 8, 2009 11:56 PM
menzfamfour
Oct 18, 2007 06:42 PM
stevtalk
Nov 19, 2006 12:51 PM
