Sponsored by: Real Truck
Clearance Lamp Question
Old Jan 3, 2008 | 07:48 AM
  #31
WildWildWest's Avatar
WildWildWest
The 7/8" hole you drilled may be a little too snug - I found that I had to go almost to 1" to get the proper fit on my lights when I installed them. This is one of the reasons I keep posting to get the 1 1/8" unibit so that you can go a little larger on the center hole. I found that when I opened up the center hole a bit more that the lights fit more flush. I also believe it will help to slightly shave/trim the foam gasket to fit once you open up the hole a little. Hope this helps.
Old Jan 3, 2008 | 08:00 AM
  #32
jeff7825's Avatar
jeff7825
I completely pulled off the foam gasket on the outer 2 lights when I put mine on. I also found out when putting my lights in that I didn't drill the 2 holes for the studs big enough the first time, and they wouldn't fit all the way down. I just had it drill to the next size on the unibit. Maybe your problem? But the gaskets definately fixed my problem on the outer 2 lights of the gap. Just make sure and use a lot of silicone.
Old Jan 3, 2008 | 10:42 AM
  #33
fdnylax's Avatar
fdnylax
I agree with Jeff, I suspect the holes for your studs are not big enough and the studs are catching, keeping the light from sitting flush. I wouldnt remove the foam backing, its there for a reason. We all have the same Ford lights and the same Ford trucks, if your lights are not sitting flush its something with the holes.
Wowabunga
Ford Truck Parts for Sale
Aug 11, 2016 03:57 PM
f100today
Jun 8, 2016 07:39 AM
Wowabunga
Mar 9, 2016 08:59 PM
81-F-150-Explorer
74
Aug 10, 2015 02:23 PM
karter81
Apr 8, 2015 09:27 AM
