Offroad & 4x4
steering problem?????
Old Nov 1, 2007 | 03:12 PM
upriverjoe's Avatar
upriverjoe
Unhappy steering problem?????
78, ford, f150, 351m,10" lift, 4x4, new stabilizer bar, 38x12.50-15s. steering is sloppy! how can i tighten it up????????.
any and all help would be appreciated very much
Old Nov 1, 2007 | 03:31 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Joe,
Im assuming that youve replaced the ball joints C bushings radius arm bushings got a drop pitman arm and the correct trac bar. If not one of those parts listed is your problem or at least a great starting point.
Welcome to the site
Old Nov 1, 2007 | 03:33 PM
75F350's Avatar
75F350
simply need to verify where it is loose. Drag link, or tie rod ends, maybe the box needs to be adjusted. Common for the rag joint to fail.
Have someone turn the steering wheel slightly from left to right, and follow all of the steering components from the steering shaft to the pass side wheel to se what does not move. A loose component will be fairly obvious to see.
Old Nov 1, 2007 | 03:36 PM
STGFordCrazy04
I guess I missed the rag joint 75. Way to be on top of things
Old Nov 1, 2007 | 05:45 PM
unrulee's Avatar
unrulee
Where is it loose, everything is likely 30 years old, pick something! HAHA
Bear in mind that you may have a little slop in multiple components, adding up to alot of slop at the wheel.
Old Nov 1, 2007 | 07:34 PM
fishmanndotcom's Avatar
fishmanndotcom
check your pitman arm. i have seen multiple cases where the large nut that holds the arm on the box comes a little loose and the arm pivots on the sector shaft causing slop
-cutts-
Old Nov 1, 2007 | 07:48 PM
upriverjoe's Avatar
upriverjoe
thanks everyone, sounds like a good start.
WidowMaker13
Apr 8, 2015 11:22 AM
dmeyer 351 4x4 rebel
Aug 18, 2010 06:31 PM
natsII
Bronco II
Mar 16, 2004 01:29 AM
Outpost22
Oct 15, 2002 05:02 AM
